Dual Rec'rs
Danny:
Am building a 4 engine multi plane,and need some help on dual rec'rs... will be using 4 servos for throttle control, 32 oz. of torgue on each one. I don't want to put a gang of servos on one channel,so am planning on using 2 rec'rs, 2 swtiches and 2 battery packs. Probably 15-16 servos will be used.
Planning on putting one rec'r on the left side of the fuse and the other on the right side...antennas will be in a plastic tube,again one one on the left,and the other on the right. they(antennas) be be on the inside of the fuse. Fuse is fiberglass.
Now I want to know if it's possible to get interfence with this set-up? If so, any suggestions on how to set it up so there won't be a radio problem.
Any help would be appreciated
thanx
Jimmy B
