RE: Showtime
I can tell you i had one lemon of a plane when i recieved mine. When i first started building it i noticed both of my wings had a cracked sheeting on the leading edge. Not knowing the extent of the damage, just sent it back to horizon hobby. After recieving my new wings went ahead and starting building the fuse. Ended up the landing gear blindnuts were mis alligned so the LG couldn't be bolted on. After knocking out the blindnuts and filling the holes, re-drilled and mouted the landing gear. Also during contruction of the tail section, my horz. stab incedence was off almost 2 degrees because of a mis drilled hole.
Now my ST is almost done, just the tedious job of progamming and setting up linkages is left. I can tell you im affraid of putting this plane up. With all this bad luck i hate to see what happends when its in the air.
