RE: hot to remove ca hinges
If you can cut out the old CA hinges with an X-acto knife, then maybe you can expoxy new hinges in. I never tried epoxy on CA hinges though; in a case like that, I switch over to dubro pin hinges, the ones with the little cotter pin, and epoxy. It'll take patience getting out the old CA hinges.
Mike
