Tekoa Roto-Cut
Has anyone here used the Tekoa Roto-Cut? I have it but have not yet tried to use it. The instructions they supplied with it are very incomplete. I have a good understanding of it’s working principal for cutting the outside templates but something has not sunk in yet for cutting inside templates. Basically what happens to the rotation point/pins as you approach the end of the cut? The whole block is supported by the two endpins and it would seem to me that as you approach the end, the weight of the foam plus the bow would fall off.
Just a technique question, what are you using to plunge a hole through the foam to get your wire through? Have you come across any pictures/articles online with the Roto-Cut in use?
