RE: banner pull
There's probably someone out there somewhere that sells them, but you can make one easily enough.
The only thing you need to do that might not be obvious, is to add a weight to the BOTTOM of the trailing end to keep it from spinning.
It's also a good idea to have a servo-release, so you can drop it before landing (Or in case of trouble)
