Not very much nylon bewteen linkage hole and the vertical bolt. You did not mention the size plane and surface area you have them mounted on. Suspect on a small control area it might just try to rotate the nylon on the bolt. Nylock nuts next to nylon would stop any rotation. You probably need more tail weight anyway.
