RE: After Run Oil to the muffler ?
It would be very difficult to get to much in unless you blocked the breather tube after you were done because, as soon as you turn the engine over any excess will be pushed out the breather tube. Probably, if you tried real hard you could do damage by putting so much in there was no room for compression of the surrounding air pocket but that would require much more than a teaspoon full on any size engine.
