3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Need help with rolling Circles
Reply
Old 01-05-2012, 09:47 AM
RKS1949
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Need help with rolling Circles
I've just started doing (trying) rolling circles. The problem is,when I'm half way around the circle,I allways begin to loose altitude. The nose just seems to fall? Any help would be appreciated! Thanks,Ron
RKS1949 is offline
Old 01-05-2012, 11:38 AM
mikesand
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Need help with rolling Circles
keep nose up before entering it..  Check you CG logitudinal and latitudinal also. CG's must be right. Use more elev when upright but watch  for excessive yaw.  granpa mike
mikesand is offline
Old 01-05-2012, 12:36 PM
RKS1949
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mikesand
Thanks,grandpa mike! I'll give it a try! I allways seem to be doing fine,until the last part of the circle. Ron
RKS1949 is offline
Old 01-12-2012, 04:27 PM
mikesand
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so do I in the last part of the circle. That is because the you are leaving the backside of the ac. when you practice again, start from the back side , see how it feels. be surprised when you catch on. tough 3D but very rewarding.
mikesand is offline
Old 05-18-2012, 07:19 AM
SuchIsLife
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm just getting a completed circle. Most of the time
The main trick for me was making it a bit more tail heavy. Also, If you lose altitude, you make your elevator movements a fraction earlier or pull a little more on the elevator. I had to reduce aileron throws at first to give me more time to react.
Agreed, really worth getting it figured out. Looks fantastic when you pull it off.
SuchIsLife is offline
Old 09-18-2012, 07:11 AM
williamdlloyd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are gradually falling after starting your rolls, you are not using enough elevator. To test, roll your plane upside down and get a feel for how much down elevator you need to hold it level. You will need slightly more when rolling. Also, I found it easier to get up to speed on rollers after I had my CG back far enough so the plane did not need any down elevator when inverted. This simplifies things a little because the amount of elevator required should be about the same upright and upside down. Good luck.
williamdlloyd is offline
Old 09-21-2012, 04:13 PM
mithrandir
mithrandir's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would suggest RealFlight Simulator!
mithrandir is offline
Reply
Display Modes
