3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
will lengthening the sticks slow down the control
Reply
Old 02-02-2013, 02:41 AM
suzonka
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default will lengthening the sticks slow down the control
will lengthening the sticks slow down the control of the ailerons ,elevator and rudder,
I have a new girl in the anger I never experienced a 540 electric edge by 3D Hobbies, with out exponential I have lowered the aileron rates as much as possible for this model to eliminate the snaps, or twitchy control because of its barn door ailerons, so if I lengthen the control sticks on my transmitter to the max, make them longer will this really help me gain a little more smoothness or control?
suzonka is offline
Old 02-02-2013, 03:58 AM
CHassan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: will lengthening the sticks slow down the control
It could. Making the sticks longer will require you to move the sticks FARTHER to get the same controls throws. That is if you fly on or near the tips of the stick.
CHassan is offline
Old 02-02-2013, 04:16 AM
flyinwalenda
flyinwalenda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you have been using the radio for some time it may throw you off a bit flying your other planes. What I do with a new , aerobatic plane is the take the recommended low rate settings and cut them almost in half and the same with the high rate settings. Take off on high rates then switch to low when it's in the air. Usually for me the elevator is touchy as well as the ailerons until I get a feel for it. After initial trimming and a few flights the H/L rates can be adjusted a bit . I try to not use exponential as I feel it's better to learn to fly the plane rather than the radio doing it BUT I have used it initially , in small amounts ,on some  planes for the first couple of flights and slowly removed it afterwards.
flyinwalenda is offline
Old 02-11-2013, 07:53 AM
Beachcomber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you don't want to lower your "rates" any further, your radio might also have "travel adjust" you can reduce the full stroke of each servo. What you are looking for is "expo" to soften the controls near center, but reducing "rates" and/or "travel adjust" is second best solution.
Beachcomber is offline
Old 02-11-2013, 09:18 AM
countilaw
countilaw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can also use shorter control arms on the servos, and move the push rod to the outer most hole on the control horn.
Frank
countilaw is offline
Reply
Display Modes
