EF MXS 64" Motor
EF MXS 64" Motor
Hi guys
I'm not new to electrics but also I'm not an expert and I received an Extreme Flight RC MXS 64" as a gift, this is the first time I have an electric plane this big. I know EF sells a motor made for their 60" series but I don´t want to have to order the motor and the ESC because I can get everything at my LHS but as far as I've seen they only sell E-Flite, GP Rimfire, and O.S. electric motors so I am wondering which motor will be best suited to the plane, I want the plane to have the same or better level of performance as the recommended Torque motor. I was thinking about the Rimfire .80 or the O.S. .40 both of these motors fall into what I think are the same power levels of the EF motor but I don´t exactly know if I'm right, and for the ESC I don´t think I will have much trouble finding the correct one at my LHS so what motor do you guys think is going to be better? I plan to run on 6 cells with 4000 mAh and a separate battery for the Rx and servos
Thanks in advance for any info
Best regards
Sergio
Best regards
Sergio
