mini E3D by Gary Wright Model Products (GWMP) - Discountinued.
Hello guys and gals!
About one solid year ago, I was fortunate to purchase this mini E3D from someone locally in Central Florida and just sat on top of my large 6 foot PT-109 RC Boat and three weeks ago, I finally put a motor / esc / RX and have had a wonder joy.
The model came with Hitec HS-55's all around and a heavier than expected Main Landing gear (Thick Wire) plus large Foam tires. I since replaced them with a firm but, thinner wire (less weight) and super light foam tires.
Certainly, didn't go with the usual motor that most have used (HACKER) and instead I used the E-Flite 480 (1020Kv) and it has not been lacking any power as this motor is a power house and don't find myself going anything past two clicks above 1/2 throttle.
Presently, it has the APC Slow Flyer 10 X 4.7 and soon I will be trying out the E-Flite 11 X 3.8 propelleropcorn:
Pic's and Spec's
Mini E3D by Gary Wright Model Products
-E-Flite 480 (1020Kv)
- Great Planes Silver Series 35-AMP ESC with Throttle Safety Feature
- APC Slow Flyer Propeller 10 X 4.7
- Thunder Power 3-Cell, 1350mAH, Lithium Polymer
- Hitec HS-55's all around
- Total Flight Ready Weight: 21 oz. <-------Reduced to 19.25 by changing out Main Landing Gear / Wheels
Pic's !
Showing new Main Gear wire with smaller / Light Wheels!
Pic's and Spec's
Pic's !
Guys,
Sunday morning was the ticket. It was just an amazing morning with calm and sunny conditions.
Changed out the Propeller from APC Slow Flyer 10 X 4.7 -to- E-Flite 12 X 3.8 propeller. Wow, it zoomed upwards at less than 1/2 throttle and it just hanged from the propeller all the way up! Found the throttle mostly right at 1/4 throttle for just tooling around.
Guys,
Just amazing conditions at the RC Club field and the mini-E3D took several flights with just spectacular results with the larger E-Flite 12 X 3.8 Slow Flyer Propeller.
Got Video uploading and in the meantime a few pictures!
Hello guys,
I have been flying the Tar out of this little and light model.
Video from Thursday, Lunch Time break!
Make sure you select the "HD" mode and Full Screen
https://www.youtube.com/watch?v=eO_-SMjdTaA
