Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
Reload this Page >
3DX: newbie to electrics and I want to know what I need
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 03-09-2004, 09:33 PM
funflyer06
Default 3DX: newbie to electrics and I want to know what I need
I'm getting things prepared to build a 3DX. But I'm not 100% sure what I need to get this thing flying. Here is what I got so far:
Motor: Himax 2015-4100
Gearbox: GWS 6.6:1
Speed Controller: Castel Creations Pheonix 25
Servos: 4 HS-55 or HS-50
Battery: not quite sure, would like some help on this one
I read somewhere for the Himax motor used with the GWS gearbox, that you have to have an adapter plate. Is that right? Any other information would very helpful. And also a few websites if you know any.
Old 03-09-2004, 11:59 PM
crashingagain
Default RE: 3DX: newbie to electrics and I want to know what I need
On the gearbox you can use the adapter available from bishop power products, or just grind a little off the ears or the gear box and add orings on the motor body for support. I use the hs 55s but am sure the 50s would be fine too. the motor and speed controll look right( use 12x6 gws prop). For the battery get a lithium polymer 3s 1320 from Thunderpower or 3s 1200 from etec.
Old 03-10-2004, 12:15 PM
3D Flyer
My Feedback: (37)
3D  Flyer's Avatar
look at the bottom of this web page for the exact spacer ring you need:
http://www.espritmodel.com/accesories_megagear.html
your setup is good, I used E-tech 1200 maH 3s1p li-poly packs.
they work great, here is a link:
http://www.parkflyermotors.com/secur...d=111&catid=19
let me know if you need any further assistance ... good luck, you will love the 3DX!
Old 03-10-2004, 08:07 PM
funflyer06
What is the best charger I could use with the lipo batteries? What is the best I could get for the least money?
Old 03-11-2004, 08:18 AM
3D Flyer
My Feedback: (37)
3D  Flyer's Avatar
I got the Hobbico MKII Quick Field Charger. It works great, can charge 2 li-polys ato once,
and the best part ... $50.00.
Note: you want to make sure you don't charge abouve 1C (if the li-poly is 1200 maH you
don't want to charge it more than 1.2 a ..... the Hobbico MKII say not above 1 a for li-polys
so your not going that much slower) It takes me about 70 min to charge my 1200 maH
e-techs from being empty.
Old 03-11-2004, 09:09 AM
patternflyer1
patternflyer1's Avatar
Etec 1200 pack and the mk11 charger are definitely the way to go. That's the same setup I have in my 3dx. Awesome power and hang time.
