AXI 2212/26 vs 2212/34
My Feedback: (12)
NJ
Hey guys,
I am seriously wrestling with which motor to get for my new 16oz Foamy? Most of my friends recommend the 2212/26 as does Hobby Lobby. The word is that it will be more efficient with a smaller prop vs the 2212/34, but I am not experienced enough with the electric stuff to honestly know. Hobby Lobby said the 34 wind would basically require a 13"-14" prop for 3D type flying....again I dunno? Any input would be appreciated.
thanks,
Leardriver
thanks,
Leardriver
RE: AXI 2212/26 vs 2212/34
With the 2212/34, you will be able to swing a bigger prop, because it is not as 'hot' as the 26. A 11x4.7 seems to be the right size prop for the 2212/34 for 3D flying, and this would provide more thrust than running a smaller prop on the 26. The 34 wind motor is better for 3D.
Stefan
Stefan
at the moment i have found the perfect combo with my axi. a 12x6 and a 830 10c mah battery from rclithiumpower.com is perfect!!!!!!! but yes it does draw slightly more than recomended by model motors ( my motor draw 11amps) but i very rarely use full power. i just don't need it. i now have a mix on my transmitter that stops the motor at about 90% power wich lets it draw 10 amps. i am currently using this setup on my 44inch 15oz foamy factory extra and it is just the perfect match. it hovers at exactly 57% power.
MT
all the planes in these videos are 16oz and flown with a 2212/26 and an APC SF 11x4.7, be sure to look at the Las Vegas video of Andrew Jeski having way to much fun!!!!!!!!
http://www.abellrc.com/new_page_1.htm
