3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
New: Eflite Mini Funtana
Reply
Old 06-25-2006, 08:51 PM
  #376
tomcatt51
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New: Eflite Mini Funtana
10x5E prop? I have an AXI 2212-20 in my GWS TM400 running a APC 9x4.5E prop, 3S 1320 TP PL. It pulls 18 amps. How many amps are you pulling with a 10x5E? Tom
tomcatt51 is offline
Old 06-25-2006, 09:10 PM
  #377
altacom
altacom's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We were drawing 19 AMPS on 2100 MAH 3S-1P packs. 110 Watts/Lb and thrust well over 100%.
altacom is offline
Old 07-04-2006, 05:56 PM
  #378
voodoo_chicken1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finally found the sweet spot to get the most enjoyment from my Funtana. My set-up is:
Axi 2808/24
Hitec 55's with long servo arm (http://servocity.com/html/hitec_micro_horns.html)
Thunder Power 3 cell 2100mah battery
Polk Hobby Seeker 6 Rx (crystal free Rx with Optic 6 Tx means I can fly on any channel!)
Aluminum Landing Gear
2.5" MPi Indoor Light Wheels (EPW250)
10x5 APC electric prop (not slowflyer prop)
Castle Creations Phoenix 25
Modifications:
Plywood beefed up landing gear area. You can see it under the covering below. Notice the nylon 4-40 bolts. Now rough landings cost only $0.50 and no more headaches! I'll switch back to metal once I get used to landing it.
That's it!
ID:	487100   Click image for larger version
voodoo_chicken1 is offline
Old 07-10-2006, 09:15 AM
  #379
elecfly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an ultrafly b/12/08 with the stock prop in my funtana, Maidend it this weekend. Seemed to have enough power but it was flying very slow. I have a 45 amp esc and 1450 mah 3 cell lipo.
Another prop maybe to make it fly faster ?
If i'm not mistaken the stock prop is a slow flyer prop ...
elecfly is offline
Old 07-10-2006, 12:16 PM
  #380
leblanc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don`t know about your setup, but I think changing to a prop that has more pitch, like a 10x7 for example, but it could as well be an 11x7, I have no experience with your motor. And also I think to have a "non" slow flyer prop thats more for 3D and prop wash if I remember correcly.
LeBlanc
leblanc is offline
Old 07-10-2006, 12:22 PM
  #381
altacom
altacom's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd suggest checking the RPM. Slow flyer props are not supposed to be used above 7000 RPM. We used the APC 10 inch electric props on our MFs.
altacom is offline
Old 07-10-2006, 02:42 PM
  #382
TManiaci
TManiaci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: elecfly
The motor has an very low Kv. 750 RPM/Volt. That's why it's flying slow, most Outrunners in this class are 900-1100 Kv. To get that motor to work, you need to go to big pitch, like and APC 11x10E to pull with any authority. The other option is to move up to a 4S Lipo to get it to turn faster.
TManiaci is offline
Old 07-11-2006, 02:58 AM
  #383
elecfly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bigger wheels also seem like a good option or just taking off the wheel pants. Landed on the grass in front of the runway , was to lazy to walk all the way to the runway , and the wheel pants hookd the grass or something and ripped the landing gear block of the fus.
Will go for the runway next time. saves me an our repair time to walk 10 seconds
elecfly is offline
Old 08-19-2006, 04:08 PM
  #384
flytime56
flytime56's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am all new to electrics, but have been in this hobby for years, small glow and large gas aerobatic airplanes.
I am looking at getting one of these planes, since I loved my .40 size funtana so much.
what do you think about the setup below?
E-flite park 480 1020KV outrunner
E-flite 30 amp ese with brake, or should I go with a castle creations 35A Esc?
11*5.5 APC prop
thunder power 2100MAH 3 cell.
Hitec 55 or 50's?
I am looking at a setup I can change between the funtata, edge and brio in the future.
Here is a basic question but I have to ask, how do you power the receiver? Is it from a lead off the esc or a seperate battery?
flytime56 is offline
Old 08-19-2006, 04:26 PM
  #385
TManiaci
TManiaci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flytime,
That setup will be just fine, strong for 3D. You will be a little dissapointed in the Mini Funtana though. It's not the best built 3D plane in this class by a longshot. It does not fly as well as the F40 or the F90, I have all three. Try the Fliton Mini's if you want a better plane for that gear...
The ESC has a lead that goes to the throttle channel o fthe Rx. It gets throttle signal, but feeds the RX and controls with power. It's called a Battery Eliminator Circuit, or BEC. No need for a secondary battery for the Rx.
TManiaci is offline
Old 08-19-2006, 05:50 PM
  #386
flytime56
flytime56's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the quick reply.
The plane i really like is the brio for it's shape and style and color. I would love to get this plane but I think it would be not enough 3d for myself.
for the fliton, would the mini extra 330 and icon 312 3d aerobatic take the same gear?
i am looking for a good built up aerobatic and 3d airplane. The only thing is I want something I can easily get in canada, so right now looking at e-flite and filton for arf's.
thanks
Geoff
Old 08-19-2006, 06:38 PM
  #387
TManiaci
TManiaci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: flytime56
thanks
Geoff
I have a buddy with a Brio. It's a great pattern plane, but not a great 3D bird. Yes, the gear you have selected will work very well in the Fliton's. I have the Edge, but it appears the Extra is much better.
You will be a bit dissapointed with any of the 3D balsa built mini's. The are all squirrly compared to thier big brothers. If you are a very good pilot, you'll have fun with them, but going down in size means everything is faster and less stable... it's just the scale that does it. You fly gassers and larger nitro planes, so downsizing you will find them less forgiving and stable. Not that it isn't fun, but unless you go to ultralite foamies, it's all about wing loading. The smaller they get, the higher the wing area to weight ratio needs to be for them to 3D really well.
good luck!
TManiaci is offline
Old 08-21-2006, 12:02 AM
  #388
altacom
altacom's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To some extent I have to agree that smaller planes are somewhat squirelly compared to their big brothers. But I've built and flown the mini Funtana, and once trimmed out, it was a lot of fun to fly just Aerobatics. Which is all I do. But in the hands of some of our club hotshots, the same plane flew 3D extremely well.
But even more fun was the BME Mini Yak. It flies like a big plane, and landings are a dream. Check it out at:
[link]http://www.e-flightline.com[/link]
As to the Brio. One of our members is a competative Pattern flyer, and flies the Brio to relax. And relaxes by doing his Pattern flying closer to the ground with the Brio. In my opinion, Designed by Quique Somenzini says it all.
altacom is offline
Old 08-25-2006, 12:03 PM
  #389
boomix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello, I have a brushless motor E-flite 370 5400kv, is there any body who knows if it will be a good option for Mini Funtana with the included gearbox (6.6:1 ratio), 12x6 prop, ...I going to use a 2 cell lipo 2100 mah ( or better 3 lipos ), instruction said this motor run on 2 lipos ????, what will happen if I make run it on 3 lipos, the motor is going to blow up ?, or instead with 2 lipos it will fly ?? .....Thanks
boomix is offline
Old 08-25-2006, 10:25 PM
  #390
griffin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got my MF ready to go, just waiting for a chance to get to the field to try it out. I have a himax 2816-890 w/ 11x4.7 prop, 2100mah 3c and e-flight 40amp esc (I know that's overboard on the esc). Does that sound like a good set-up? I'm still pretty clueless about this electron powered flight...
griffin is offline
Old 08-26-2006, 01:47 AM
  #391
TManiaci
TManiaci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: griffin
That a preimium setup for that motor. Right at the top of the rating charts. It should make about 200 watts on a fresh battery, which is good enough to 3D okay. Not ballistic, but adequate.
Good Luck, and have fun. Dial the rates down on the elevator till you get a feel for it, it's a little touchy.
TManiaci is offline
Old 08-26-2006, 02:54 AM
  #392
griffin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks TMan,
It's good to know my LHS is giving me good advice, because I sure don't know. I have a blast with the F90 and I'm looking forward to trying out little sister. I'll remember to keep the elevator on mellow for the first flight.
griffin is offline
Old 08-27-2006, 12:23 PM
  #393
Mikel-t
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I maiden the MF last week and using the called for CG I had a large tail-heavy condition. I tried trimming it out first ( no-go) then landed to check equipment ( nada) . After reading a lot of this thread decided to put the ELEV Servo and RUD servo in the fuse @ the TE of the wing. I'm using the front wing placement with the below set-up.
I needed to add 2oz. of weight in the cowl to get it to balance @ 75mm from LE. It is flying stable enough now but forget anything 3D or highly acrobatic! Any ideas?PLEASSSSSEEEEEE AUW @ 27oz WOuld moving the wing to the back position have any effect on CG??????
Steerable tail-wheel from Piper Cub.
6.6:1 gearbow w/Park 400 motor 4200Kv
E-flight 20 amp ESC velcro on firewall under stick
TP 1320 PL, against front Firewall
JR 6ch Rx over CF wing rod
Hitec 55's inside fuse at wing TE.
Mikel-t is offline
Old 08-29-2006, 12:18 PM
  #394
lthibault
lthibault's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My setup:
- EF Park 480
- EF 40 AMP ESC
- TP 3C 2100 MAH
- JR micro servos all around w long arms
- Aluminium landing gear
- Nice red spinner and 1/6 Pilot
Technical report / improvements:
-Sweet plane, very powerful with this setup, can perform acrobatic manoeuvers and hover
-Had to reinforce the area under the landing gear and got rid of the weak carbon figer gear
-Also put piano wires to the stab to reinforce it
-Steerable tailwheel (Dubro)
-Wheel pants are rock-solid with blind nuts & screws passing through the aluminium landing gear
With just a few improvements, I have nothing to say against this product, it is an everyday plane that can go easy or very acrobatic. Lots of fun and many hours of usage.
Enjoy!
Will post pictures later.
lthibault is offline
Old 08-29-2006, 08:57 PM
  #395
lthibault
lthibault's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's some pictures. First, my sweet MF:
Old 08-29-2006, 09:01 PM
  #396
lthibault
lthibault's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Steerable tailwheel, stab reinforcement and a view of the landing gear & wheel pants
ID:	515591   Click image for larger version
ID:	515592   Click image for larger version
ID:	515593   Click image for larger version
Old 02-19-2007, 01:45 PM
  #397
lthibault
lthibault's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well folks, it was time for an upgrade and after many many enjoyable sessions my MF's exterior has been put to rest. Transferred everything in the new Mini-FuntanaX that I should maiden any day now.
