Landing in grass with lightweight 3d planes
What is your choice on protecting your fuse bottom when landing in grass? Nose and tail.
Are you leaving the landing gear on and just coming into a abrut stop? Tape? Plastic reenforcement?
Now I realized for thoses of you who can pluck the plane right out of the sky this dosen't matter, but I'm not that good yet.
TN
RE: Landing in grass with lightweight 3d planes
I'm not that good to pluck it from a hover either. What I do is line the bottom with some packing tape and it does fine (if you are using a flat profile plane that is). Keep the throttle on and come in with the nose pretty high up. Kind of like a harrier that is descending and is at about a 25-30 degree angle instead of a 45 degree angle. Just before the tail touches down turn the throttle off and the rest of the plane will just plop down and because the motor is off (hopefully) than the prop will just move out of the way when it hits. Every motor off touchdown I make the prop is horizontal to the ground.
By the way, the plane I use this method with has no landing gear. But I'm sure it could work kind of the same way. Maybe you'd want the gear to touch before the tail though...
Thanks for the suggestion, I haven't decided if I want to mount the gear or not. Leaning towards not, since allmost all my flying will be on or over grass.
Mike
Mike
IA
If you are flying a foamy, I just put a strip of carbonfiber from the tip of the nose about half way back. If it is a wood plane you might try the same other wise just do the same as flyingace says to. The landing gear could be bad. For one it is weight. For two it can make the plane fly completely different.
If the plane will harrier it will make landings easier. Also landing in tall grass helps considering you have a light plane.
VA
I fly off pavement at home and short grass, 1"-2", at the flying field. All my planes have landing gear and 1.5" wheels. My Eflite Ultimate has no trouble taking off from the grass at my flying field and lands just fine on it as well. In fact I even do touch goes with it, sometimes only the tail touches, oops did I say that.
Planes don't last as long without gear from my experience. My Eflite Ultimate has over 41 hours of flight time on it and it's in decent shape.
VA
Just catch it from a hover!!!!
Another issue is the weather. Most of my flying is done in 10-20 mph winds, it's always windy at my house. Keeping a steady hover in that wind with a 12oz foamy is very difficult.
I know a lot of folks catch, snatch, them from a hover and never have any problems. I won't be 1 of them. Just my 2 cents, not trying to stir up the pot.
just wear a paint ball mask, some cardboard across the front of your body, and some gloves for the first few tims you try catching it. I'm goin to do that with my flatana. also try flying it strait and level with just the elevator and aileron sticks cut the throttle and let it glide into your hand. Trust me, it's not that hard, unless the wind is bad then it is........
ORIGINAL: Ryguy
VA
It can be done. I could do it. I'm not going to do it though. It could be dangerous and certainly would set a bad example for my kids.
I have caught my gliders for many, many years.
