Aileron servo arms for HS55
Hey all,
What are the best arms to use on HS-55 for the ailerons of the Inspire Mini? I only had one of the large double arm so I ordered an arm pack but it didn't come with the large one, so I still only have one.
Which arm would you recommend I use? (no dirty comments either! )
Cheers!
EDIT: I found this:
http://www2.towerhobbies.com/cgi-bin...?&I=LXLPF1&P=M
Are they any good? Or is it that cheap brittle plastic that breaks if you breath too hard?
Cheers!
EDIT: I found this:
IN
RE: Aileron servo arms for HS55
Thats what i use! MICRO XL S3108M/HS50/55
http://www2.towerhobbies.com/cgi-bin...?&I=LXLPF1&P=0
Steve
VA
The Dubro 3D arms are great. I've got them on all my park flyers now and the amount throw available is insane(like 90 degrees) if the control surfaces are hinged properly.
Well tower hobbies has them but the postage to the UK is ridiculous, and it would take about a month to arrive.
Are these the same thing?
http://www.jperkinsdistribution.co.u...bcatname=Dubro
Both reference to a product number of 930.
