Best LiPo Charger? ? ? ? ? ? ? ?
KS
Hello,
Just trying to get some opinions. I am looking for a LiPo charger that can charge mulitple batteries at once. I also need it to charge 7+ amps. What do you guys think the best LiPo charger on the market is that meets this criteria??
RE: Best LiPo Charger? ? ? ? ? ? ? ?
Check out the Thunder Power 1010C and the 210V balancer. I have more info. posted on my store site listed below. Goes up to 10amps, 10 cells and with the proper setup and connectors you can charge anywhere from 2-4 packs at the same time I believe.
KS
The charger looks good but you can only charge one battery at a time from what I see. I am getting ready to convert a 50cc plane to electric and I am going to use three 14.8v 4600 mAh batteries and I would like to charge all three at the same time.
Thanks for the post
Thanks for the post
There is a manual on the Thunder Power Website that has a diagram connecting several packs via the balancer to one charger - http://www.thunderpower-batteries.co..._manual_R3.pdf
KS
thanks flip. I was hoping that I wouldn't have to do it through balancing the packs but it looks like that is going to be my only option. Thanks for you help.
