Precision Aerobatics Addiction
#126
SC
RE: Precision Aerobatics Addiction
My hatch came off once. I was in a full vertical dive, full throttle, and i pulled a hard barrel roll when it popped off. I only did that once, and i haven't tried the maneuver since. When has it been happening for you?
#127
Mine does it high g maneuvers-like blenders, tumbles, etc. I would not worry about it coming except our field is surrounded by corn. If it goes in there, it's gone.
I believe the issue may be top magnet seems a little recessed and not flush.
#128
ORIGINAL: rightflyer
Anyone else have any issues with their hatch flying off during some maneuvers?
I would recommend that you check the magnets to see if they are dirty, sometimes they pick up dirt and because of that they have less strenght, but as soon as you clean them they are like new again.
#130
SC
Ok, i got my new motor cage in today. Has anyone else out there changed theirs out before? If so what is the best way to do it? It looks like mine is only held on by thin CA, do they make some kind of CA solvent that i can soak the hinges in to completely loosen it up? If so what is it called, and if there are different kinds then what do you suggest is the best one?
#131
ORIGINAL: AnAlternateEgo
Daniel
#132
SC
I just ordered the wheelpants for my addiction, will I have to buy longer axels to install them, or have I just been installing them wrong so far?
#133
SC
My new motor cage finally came in. I had no problem removing my old cage from my addiction. Upon installing my new cage, i noticed something didn't look quite right. One side of my motor cage measured 1/16" longer than the other side. I know this doesn't sound like much, but if you set the plane on its nose, one wing is about an inch higher than the other. I have e-mailed precision aerobatics tech support about this but i havent heard any replys from them. I just wanted to make sure that this isn't normal, which i cant imagine how it would be.
#134
SC
Ok, i finally got a reply from PA today and they say that the cage is supposed to be longer on one side. Next question, what props do you all suggest i use? I know what the PA site says i should use, but i wanted to know what your personal experiences suggested. One thing particularly, what prop do you suggest i use for extended flights? My local club likes to have electric endurance challenges to hand out prizes, what prop do you find is the most efficient? Oh, and i have the thrust 20 motor with quantam esc and a 2100mah battery.
Does anybody know where i can find a WHITE spinner for an addiction? Also, please refer to my wheelpant question a few posts up. THANKS for ALL your HELP!!!
#136
My new motor cage finally came in. I had no problem removing my old cage from my addiction. Upon installing my new cage, i noticed something didn't look quite right. One side of my motor cage measured 1/16'' longer than the other side. I know this doesn't sound like much, but if you set the plane on its nose, one wing is about an inch higher than the other. I have e-mailed precision aerobatics tech support about this but i havent heard any replys from them. I just wanted to make sure that this isn't normal, which i cant imagine how it would be.
#138
SC
ORIGINAL: Jomamma
Where did you order your motor cage from.
I need one
I need one
#140
My Feedback: (110)
PA
the addition is a nice plane. had one for a year. learned to hover on it. got it from alantia hobby. torque motor , castle thunderbird 36 amp esc, 2200 ..11.1 volt 3s 25c lipo. flew great. grass field, watch the landing gear it's carbon fiber two piece. just put outside fake wheelpants on it. they don't last long on grass. took the electrics out after a year. it had been crashed four times, and put them in a reactor ep. doesn't hover as well as the addition but cost 50.00 less and is a cool looking plane.........GEETER
#141
SC
I've recently gotten my ADDICTION air worthy again. With my new thrust motor as the power plant, i have noticed that when i slowly throttle up the prob will spin backwards 3 or 4 times and then begin to spin in the correct direction. Is this normal or do i need to switch around some connections?
#142
http://www.thrustmotors.com/instruci...structions.pdf
Daniel
#143
SC
So it isn't hurting anything the way it is though, right? I have no problem with it the way it is, i just want to make sure that it isn't doing any damage by flipping backwards in the beginning. Is there any specific reason i should turn it off?
#144
SC
I am flying with a Spektrum Dx7. I was wondering what the typical settings are in the radios of the experienced pilots on here. What end point settings do you all use, rates, ect....? Thanks for all the info.
#145
Good Question- I originally set up the plane up with what I thought to be standard rates as in the manual.
After flying the maiden (and thinking damn this things twitchy) I discovered all surfaces were over 60 degrees- at almost 150% on low rates!
This must have happened when the model was rebinded!
The original setting were established, and the plane set to low rates for the 2nd flight!
A lot easier to handle!
Not being used to expo, this taken getting used to. I am considering reducing throws and expo, (both high and low rates) as this feels the logical thing to do to find the right balance.
I believe the best settings are "What feels right for you"
Will give updates shortly- weather permitting!
#146
SC
I acquired my Addiction used and it didn't come with the manual. I have looked and asked all around but i can't seem to find a pdf of the Addiction manual anywhere on the net. Could you please let me know what the manual suggests. I have just been flying my Addiction at 100% throws on a linear curve. What are the suggestions for beginner/intermediate/advanced flight?
#147
TX
GA
For rates these are mine on low...45% and 35% expo all around and on high...ail.. 70% with 35% expo, eve. 60% with 40% expo, rudder 90% with 40% expo.. Those high rates are enough to do any 3D work and its not too twitchy.. I like the 11 x 5.5 with the Thrust 20 motor as its the best overall prop...For the hatch I had to add a magnet in the center off another model to keep mine on...Just glue one between the other two and the other one on top of piece in the center...hope that helps...Jason
#150
I dinged my Addiction into a ceiling trying to fly indoors a year or so back (ambition over ability!!!!).
I'm finally lining her up for repairs and noticed that some folks had also dinged theirs and bought a replacement motor cage - didn't even know this was available! Had a search round in the UK and it's a tenner, so once I've checked out the damage that will hopefully speed up the repairs no end - thanks for the tip! Had images of me trying to cut some intricate ply fretwork... [X(]
I'm also going to replace the Turnigy motor (it was one of the original super-budget items and vibrated like stink) with a Dualsky XM3530CA-12, which looks about similar to the PA Thrust 20.
Looking forward to getting it in the air again.
