dx7 aileron adj?
WA
dx7 aileron adj?
hello i'm wondering if someone knows how to adjust these i have a dx7 and a pitts biplane with dual aileron servos have the radio set for flaperons so they both drop at the same time for landing and high alpha flight but my prob is i have plenty of down travel on the ailerons i cant for the life of me get more up travel,not in flight mode 2 but regular flight mode when turning the aileron has plenty of down travel but not much up tried end points and percentage settings anything i'm missing? thx
oly
oly
My Feedback: (18)
FL
RE: dx7 aileron adj?
Once you have it set for Flaperons....Then go into Aileron Differential. That should allow you to set different throw up and down. I hope that is what your asking....
NH
I've experienced the same as the original post.
In order for the ailerons to work properly you must select "rocker" type once you've selected a flaperon fuction with dual aileron servos. Then while normal operation, both ailerons will give equal deflections both up and down. Although, your post is a little vague. Are you trying to set a true flap mode with a biplane? If so, I don't know how to increase the "up" deflection while in flap mode. I wouldn't worry about it unless you're experiencing abnormal flight characteristics. I can't imagine wanting to fly a biplane slower than it already does though. Best of luck.
WA
antennaman,maybe my post was kinda vague lol but you seem to be able to fill in the blanks,your answer was just what i was looking for,now my ailerons have the same travel up as down,before they had a lot of down and not much up aileron thx much
