3D Hobby Shop 47" Edge 540
CA
Look what I see.
http://adchobbystore.com/3dhobbyshop-EDGE47-R.htm
http://adchobbystore.com/3dhobbyshop-EDGE47-G.htm
From the 3D Hobby Shop website:
This 47" Edge 540, developed by Scott Stoops, is a fantastic performer. Light KE coupling, no wing rock, excellent pitch authority, great all-around flight performance....all in a durable lightweight package. The Edge is really, really easy to assemble, too. The wings are easily removable, and ride on a strong carbon-tube wing spar. The landing gear is one-piece, molded carbon-fiber and mounts to a strong, composite-reinforced plate. The motor box is pre-assembled and pre-drilled and nutted for many popular 28-30mm outrunners. The tail feathers are fully-airfoiled for highest performance.
The Edge includes ball-link/phenolic control hardware, and is covered in genuine Oracover (Ultracote) covering. The green version is done in beautiful pearl metallic green. The red version is beautiful true red, just like the full-scale RedBull air racer.
Specs:
Wingspan - 47"
Wing Area - 450 sq. inches
Weight - 37-41 oz. depending on setup, lipoly pack
Spinner - 40-42mm or 1.75"
Use Hitec HS-65HB or HS-65MG servos. Long servo arms are required for full 3D throw.
The Edge 47" requires a brushless outrunner motor 108-148 grams weight. Good choices include: Torque 2818T-900 or Hacker A30-16M for lightweight setups with 3S 2100-2500mah lipoly packs. For more power, use a Reaper GR-35 on 3S or 4S, or a Torque 2814T-820 on 4S 2200.
Build videos:
http://vimeo.com/2195889
http://vimeo.com/2196077
http://vimeo.com/2196465
http://vimeo.com/2196772
Specs:
Wingspan - 47"
Build videos:
RE: 3D Hobby Shop 47" Edge 540
With how great the little 40" EDGE flies, it is inevitable that the 47" will wind up in the hangar at some point.
Really great work on the build videos.
TX
This is the best 47" plane out there in my opinion. The confidence this plane gives an average pilot like myself is pure greatness. Here is a video of the 6th flight on this plane.
http://www.youtube.com/watch?v=RE2cT4tlW_Y
dp
dp
CA
Here's a couple videos of the 47" Edge.
One in clean air
http://vimeo.com/2537447
and one in some pretty good wind.
http://vimeo.com/2535750
One in clean air
ORIGINAL: DPRC
dp
dp
ORIGINAL: ipsmotors
One in clean air
One in clean air
Nice work!
Here's a little video, just goofin' around in a small little pee-wee baseball field
http://www.vimeo.com/7810468
http://www.vimeo.com/7822271
http://www.vimeo.com/7830546
More video
Robert Cantu - RCDRUM
Hacker A30-16M w/ X-40-SB Pro
Turnigy 13x6 Electric Beechwood
Thunder Power 2100 V2 Pro-Lite
http://vimeo.com/9846383
