Typhoon Prop?
GA
Typhoon Prop?
I'm confused about the prop situation for the Typhoon 2.
I am a pretty good pilot, if I say so myself - but I am so clueless about matching props up with motors, etc, etc.
For Hovering, Harriers, etc, should I be using the prop Parkzone lists as being "Ideal" for the 11.1 Lipo? Or the biggest prop that it came with which Parkzone says is good for "Peak Vertical Performance."
I'm using this to play with my 3D maneuvers outside the house. Nothing special, just basic 3D.
My Feedback: (10)
CT
RE: Typhoon Prop?
If you are planning on hovering around the neighborhood, I think you want the 14 inch prop. The other one is supposedly for 'aerobatics' or 'speed'!! I fly my Typhoon with the bigger prop most of the time as I use it to attempt to practise 3D.
Hope this helps!...Chris
