What foam plane for Park 370 motor?
I have a E-flight Park 370 in-runner motor and gearbox. Who makes a good foam 3D plane that would be good for this motor? I have a 1st gen. e-flight mini funtana kit but it calls for a Park 400 motor. would the 370 be enough for that plane?
RE: What foam plane for Park 370 motor?
hey,
The Mini Funtana has a flying weight of roughly 24 oz. The E-flight 370 Motor is for small airplanes between 10 oz – 14 oz. I would say that you need to try and find something else for that motor.
[link=http://e-foamies.com/extra300s.html]Check out these airplanes! [/link] You can see that most/some of the planes fall into the perfect weight for that motor. I would also look into any profile plane with a similar wing span.
Good luck.
Z
Good luck.
Z
