RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   3D Electric Flying! (http://www.rcuniverse.com/forum/3d-electric-flying-237/)
-   -   hacker on yak and bipe (http://www.rcuniverse.com/forum/3d-electric-flying-237/1396609-hacker-yak-bipe.html)
Dewey2 01-02-2004 06:03 PM
what kind of prop will i need to run on a hacker on the foamy factry bipe and yak. i think i need the hacker b 20-26s+4:1 gear box is that the right one. also can i pull the skin off the foam. i don't like the way it makes the foam. look and my paint won't cure on it thanks.
3dnut 01-02-2004 08:40 PM
RE: hacker on yak and bipe
the skin on the foam is what gives it the strength and flexability. an alternative for painting a scheme use sharpe markers. they take a little while to cover large surfaces but it turns out pretty nice. they have a varity pack that has many different colors and the best tip is the chiseld tip. will
Av8er Tim 01-05-2004 07:56 AM
prophanger1 - I would go with an APC 11x4.7 to start with. That combo should give about 22oz. thrust at 11 amps. Leave the skin on! It adds tremendously to the stuructural strength of the foam.
Tim
