Best INDOOR 3D PLANE??
Reply
Old 02-11-2011, 09:47 PM
XxOoCoBrAoOxX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Best INDOOR 3D PLANE??
Hey guys im wondering what is a great indoor 3d plane that doesnt cost much? Im only looking to spend about $100-185.
In the past ive built 2 indoor planes but they both came out to be too heavy because I used a 70g motor a 3s 800mah. Please link some really nice electronic setups with the arf planes. And what do you guys think about using hot glue at a low level heat? What is an alternative to hot glue that does a better job and doesnt put on a lot of weight?
XxOoCoBrAoOxX is offline
Old 02-12-2011, 04:05 AM
aussiesteve
aussiesteve's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Best INDOOR 3D PLANE??
a 4-Site is pretty good fun indoors
If you have a reasonable indoor space to fly in - a Thunder Tiger "EPP" series plane is a blast also. I have built a lot of them using hot glue (and Staples for holding the hinges in place) - never had a problem with that.
aussiesteve is offline
Old 02-12-2011, 05:42 AM
ohnoucdat
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
3DHS extra http://www.3dhobbyshop.com/33-EPP-Ex...C_p_15759.html
ohnoucdat is offline
Old 02-12-2011, 08:56 AM
k12rc
k12rc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
check out fancy foam rc they have the best flying ones ive found most around 6 to 9 oz depending on you and how you build
k12rc is offline
Old 02-12-2011, 02:36 PM
XxOoCoBrAoOxX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey thanks for that suggestion. I took a look at the plane but what kind of glue should I get to build her? And is there a certain technique when we apply that hot glue...? It is kinda heavy but I'm not to sure... Wouldn't CA crack the flushed edges?
Let me know guys and please keep bringing in the planes...
Also what do you guys think about the new BNF Extra from Horizon? I have a dx7 and that would be perfect, but it seems kinda pricey...
Old 02-12-2011, 02:44 PM
k12rc
k12rc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
use foam safe ca Iuse the new 11x JR with the 6300 or 6100rx the one with end pins to keep it light don't use hot glue
k12rc is offline
Old 02-13-2011, 05:33 AM
Zippi
My Feedback: (10)
Zippi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.commonsenserc.com/product...oducts_id=2422
Zippi is offline
Old 02-21-2011, 05:38 PM
lokiyawl
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: XxOoCoBrAoOxX
The best bang for the buck has to be the Eflite 4-Site which you should be able to find for under $70 RTF. I have owned 6 of these little planes and have accumulated more than 200 hours on them. You will want to modify the battery installation, it is actually on the wrong side of the plane! The plane is heavy on the RH side without the battery, which is designed to be installed on that same side so the CG in stock condition is way off to the RH side, move the battery to the LH side of the model and it will fly much better. Also move the battery lower (greatly improves high alpha harrier) on the fuse and get it back to about where the carbon rods supporting the wing are. This should give just a slight push when inverted and will reduce the tendency this plane has of dropping the nose with rudder inputs. And if you kill your 4-Site airframe there is a multitude of aftermaket airframes for your gear. There are much better flying models than the 4-Site but not for the same money!
James
lokiyawl is offline
Old 02-21-2011, 06:14 PM
drumbum
drumbum's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
James
Do you have any links?
drumbum is offline
Old 02-22-2011, 03:55 PM
tee681
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
delux v3 from donut modles best plane you will ever fly the 4 site is junk
tee681 is offline
Old 04-30-2011, 08:13 PM
lokiyawl
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: drumbum
James
The best Micro 3D plane I have ever built and flown is a lightened (use 2 MM foam instead of the stock 3 MM, use RC Canopy glue and UHU where possible) version of the Donuts Models Micro Aito. I built one using the power system out of a Eflite Micro Beast that came in at 53 grams less battery. The second one used the 4-Site components and an AP05 on 2S with 120 MAH Lipo. That power setup makes more than 100 grams of thrust and my plane came in at 48 grams (less battery) ..it is a BLAST to fly. Doing rollers 6" off the gym floor is a cinch with ths plane. Edges really nice too. James
lokiyawl is offline
Old 04-30-2011, 08:18 PM
lokiyawl
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: tee681
The Eflite Micro 4-Site is a great little plane. I have accumulated about 200 hours of flight time on the 6 that I have owned and have done a lot of trimming to improve them. You have to use good batteries to realize the potential, the stock Elfite batteries just don't cut it. Use Hyperion 160's, 180's or the Thunderpower 160's and the power is great. I usually get about 25-30 hours on the stock motor before the power begins to fall off.
James
lokiyawl is offline
Contact Us Archive Advertising Cookie Policy
