Hype 3D CG ?
Hype 3D CG ?
Made mine with CG "by the book" as recomended.
Hype owners how do you setup yours ?
I have feeling that it should be waaaay back.
RE: Hype 3D CG ?
Don't have the manual on hand but my came good at 175 mm.
Had to add 50 grams of lead at tail.
All up weight with
- W50T1
- 3x Futaba S9001 (ailerons, elevator)
- 1x Futaba 3003 (throttle)
- 1x GigaLine MG (rudder)
- 5x Sanyo Gold 100 mAh
- Kawan 250ml replacement tank (original is POS)
- Carbon LG and canopy, no spats (kept loosing them...)
- beefed up landing gear mount plate (too fragile for my taste...)
is 2300 grams on scale.
All up weight with
- W50T1
My Feedback: (27)
MI
RE: Hype 3D CG ?
mine is at 165 mm with a YS63 4stroker
hitec 5475 digitals on all surfaces and a hitec 85 mini on
throttle. standard gear and no spats or pants if your from here
also a 700mha battery, which is just foward of the canopy along w/ the reciever
havent flown it yet due to snow
cant wait!
cant wait!
