What is a good first 3d rc plane
HI guys i can fly rc planes but i only really fly vintage style planes and the occasional warbird and lately i have been thinking a lot about 3d lately so i was wondering what would be a good plane to learn 3d flying on i had a go on a friends parkzone sukhoi and it was fun but i only managed a few rolls i am relly thinking of something small like a micro or a parkflyer but if something bigger would be a lot better i would probalbly go for that.
I like building kits so am quite versatile to state of assemly.
RE: What is a good first 3d rc plane
Go for a Profile. If you have even basic building Skills, a MoJo of the size of your choice. Otherwise there are a couple of decent ARF ones out there. Maybe someone will chime in on the better of the ARF profiles as the only ones I have any personal experience with are from kits and even witn my mediocre skills I can build most of the Profile Kits in a few days.
Nothing beats a decent profile for 3D
Cool if you know where i can get plans i could build one from those very easily. i have plans that i got in a magazine for an edge 540 what do you think about those?
go with the fun world 3D from world models
this plane is built for a brushed motor, so when you load it with a brushless motor it will be very good for it, plus this kit is very cheap, less then 40 U.S dollars and it is very easy to controll, if you want videos visit
http://www.youtube.com/user/3DPlaneF.../1/XX_GoJYDNrc
this is my plane with dualsky brushless motor and JR mini servos and a 11.1 volts 2650 mAh you could go for 9 minutes of intense flying
VA
Bouncer for foam = http://tufflight.com/bouncer.html
Mojo for balsa kit = http://www.swanyshouse.com/mojo/mojo.aspx
Sabre 47 for balsa ARF = http://wwww.valuehobby.com/product_d...=50&item_id=46
BC, CANADA
skip the micro stuff, they dont fly that well and are not suitable for learning 3D
You need to decide if electric or nitro would be your power choice.
If money is not a problem then it does not matter, but its best to pick a power plant that can easily transfer into other aircraft that you may like.
I'd get an electric that uses the common and readily available/cheap 2200mah 3S lithium, this battery is widely used in many good airframes from foam to balsa and helicopters.
If going nitro a good bearing .46 to .55 or bigger is desirable.
4 strokes are often preffered as they have a lower available power curve and torque.
.72 to .91 are common mid size motors in 4 stroke nitro.
So follow up.
I got given a UMX extra 300 and I loved it and could hover for 3+ minutes in the living room.
But I got damaged in transport so I decided to order a mojo .60 do we will see how that goes.
Indra
MO
These planes are awful hard to beat
http://www.3dhobbyshop.com/ARF-Airplanes_c_183.html
VA
ORIGINAL: nitroairplane
So follow up.
So follow up.
Indra
Excellent choice!
Hopefully soon I can be part of the profile brotherhood lol
From what I have done 3d Is so damn fun!
Went for the mojo because I wanted something I wouldn't be afraid to throw about and try new things with.
