Any Good Gas 3D/Freestyle planes under 50cc's
My Feedback: (62)
NJ
I noticed a couple of similar threads, but they didn't seem to stay on topic or answer the question.
Is anyone flying a 3D/Freestyle type plane under 50cc's that isn't nasty or erratic?
I have a couple 35% gassers, but don't always have the time to get to the field for a day of flying.
Just looking for something to keep in the truck and kick around with when the opportunity arises.
Thanks for any thoughts and opinions.
RE: Any Good Gas 3D/Freestyle planes under 50cc's
Ah gotcha, how about the Extreme Flight 78" Extra with a Syssa or similar.
(yes I have one of those as well)
Built light, huge control surfaces, and comes in both gas and electric versions. I run mine with an MLD 35 that I had to stick a DLE 55 carb on to get it to run well.
My Feedback: (62)
NJ
What do you think of the flight characteristics?
Gentle enough to be fun?
Spirited enough for freestyle and 3D?
Bob
Bob
Its very light so it tollerates a bit rearward CG for really flat spins, it gets around its elevator axis faster than anything I've flown except the 50cc Sbach.
Move the CG up a little and it does lazy IMAC but its a little light to be real tight on lines.
Sport flys great on more conservative rates.
MI
bob
check out this thread. its short but he has a 71" slick.
http://www.rcuniverse.com/forum/m_10660748/tm.htm
My Feedback: (62)
NJ
I will, thanks!
I'm considering a new / never flown 70" Slick in my area with a DLE 30.
Trying to learn about the DLE and read as many threads as I can on the Slick.
Do you fly a Slick?
Take care
Bob
Do you fly a Slick?
Take care
Bob
IN
ORIGINAL: bob_nj
I will, thanks!
Do you fly a Slick?
Take care
Bob
I will, thanks!
Do you fly a Slick?
Take care
Bob
IN
ORIGINAL: bob_nj
Good to know.
Do you have the rear carb DLE?
Good to know.
Here is a video of my third flight...
http://youtu.be/65ZsGdbvfn0
IN
ORIGINAL: bob_nj
Maybe it's me, but I can't get the link to work!
Go to you tube and search under CRFan250...you will find the Vid there
My Feedback: (62)
NJ
Got it to work, thanks.
The plane looks like a lot of fun.
It should be a bit of a break after flying the big stuff.
Just keep it in the van and get to the field for those "quickies" [X(]
I should be getting mine this Saturday.
Will have to keep an eye on the weather this weekend.
Irene is knocking!
Take care
Bob
Irene is knocking!
Take care
Bob
IN
ORIGINAL: bob_nj
Irene is knocking!
Take care
Bob
Irene is knocking!
Take care
Bob
My Feedback: (68)
the 30cc market has come into its own. I would consider these for your perusal
http://shop.aztechaeromodels.com/25_c16.htm
http://shop.aztechaeromodels.com/25_c13.htm
they are currently offering free shipping on all ARF's right now
good luck
good luck
My Feedback: (62)
NJ
Thanks for the info.
With my work schedule, I looked around for something ready to fly that wasn't too far away and found something.
It's the older 70" Slick ready to fly.
It's new and never flown with a DLE 30.
I'm looking forward to something different and this should be fun.
Take care
Bob
Take care
Bob
FL
ORIGINAL: bob_nj
I was looking at the 3DHS 68'' Vyper initally, and then the 71'' Slick.
Anyone flying either one of these planes?
I have a 65 vyper ..... is there a 68 ??
it's such a great electirc plane and its so light i dont see any need for gas or puting a gas motor in there but you could
I'm under 8 pounds with 2000 watts
My Feedback: (62)
NJ
It is 65", sorry for the typo!
I should have the 70" Slick later today if the storm doesn't mess things up earlier than expected.
I'll let you know how it shakes out.
Take care, and stay safe this weekend.
Bob
Bob
IN
ORIGINAL: bob_nj
Bob
Bob
My Feedback: (62)
NJ
Got the Slick on Saturday.
I'm going through it real good to get it the way I like it.
Not going to use the stock chinese tank.
The needles are going to be a challenge.
The engine is rear carb, and low end sits right against the lower front part of the firewall.
Had t replace the choke servo as the servo in there was stripped out.
That's also a challenge with the limited amount of working space available.
All in all I've got a couple more days before it's ready.
Supposed to camp at the field next weekend, but the storm has set some of the guys back a little.
We'll see.
Have a good day
Bob
We'll see.
Have a good day
Bob
IN
ORIGINAL: bob_nj
We'll see.
Have a good day
Bob
We'll see.
Have a good day
Bob
http://www.aero-works.net/store/sear...CategoryID=164
I went with the 8oz one to save weight. I use 4 ounces in 8 minutes of flying so you could do 10 easy. As far as the choke, I personally would just do a manual set up...cheap easy and light.
