Reload this Page >
peak model/redwing/chinese 20cc profile dle 20 build
Old 03-14-2012, 11:01 AM
raydar
Default peak model/redwing/chinese 20cc profile dle 20 build
Reached the point in flying where I feel the need to try prop hang everything I fly lol. Sig hog bipe, 1/4 scale pitts, and even a spacewalker lol. Decided enough was enough and bit the bullet and invested in a peak models 65 inch profile and dle 20 engine, this gives me the tools for the job im sure.
Just for some background I will say I bought the peak models profile as it filled certain criteria, it was a ARF (have a goldberg sukhoi mx26 kit on the build table), it was availible at a reasonable price in the uk, it is not a foamie and it is a good size. I realise there is other models out there and foamies are the best way to learn 3d and bigger flys better but this model ticks most boxes for myself.
As for the dle 20 well It has to be gas for me, electric just does not do exite me personally. I have had a couple of rcg 20 beam mounts from hobbyking and they have flew with great reliability and power, though cheaper than the dle 20 I thought I would splash out on the dle 20 and see how it compares.
The model willuse onelife battery, no regulators or diodes, a kill switch and cheap metal gear chinese servos, in fact I might use chinese only products on this build and see how I get on.
This model is availible from alot of vendors not just peak models.
The build starts tomorrowafter my nightshift if it is to windy to fly.
ID:	1738690   Click image for larger version
ID:	1738691   Click image for larger version
Old 03-15-2012, 01:50 PM
raydar
Default RE: peak model/redwing/chinese 20cc profile dle 20 build
The model was ordered from china from madaboutrc.com and came with free delivery and customs already paid, the model arrived on the sixth working day after order, it was well boxed and arrived in perfect condition.
The first impressions of the model are good, the covering is exellent and what you get in the box is of good enough quality to use. carbon fibre wing tube is included as well as fuel tank with gas stopperand fittings, wheels, and aileron and elevator linkages. I will include more about these as I continue with the build.
the model has been built clearly with the dle 20 in mind for the powerplant as a cut out in the fuse marries perfectly with the dle 20 muffler.
This is a link to the online build manual of the model.
http://www.peakmodel.net/sbach20ccmanual.pdf
The model is not supplied with a paperbuild manual but a micro disc that basically has the pdf that is linked to above.
Old 03-15-2012, 02:00 PM
raydar
Went to the club today, got one flight with my sig hog bipe as was busy helping a fellow modeller get his first gasser in the air most the afternoon.
Managed to lock the hog bipe in a hover for a while even though I was about 150 feet up and it was difficult to see well and react to what was happening, anyone says a hog bipe cant hover is wrong lol, im a 3d begginer and can manage a somewhat high and messy hover. Still this is one of my kit builds and dont want to crash her trying 3d stuff when clearly although she can hover she is far from a 3d machine with the power and agility to get me out of trouble at a low altitude. so when I got home I started on the sbach profile build.
First thing I want to do is fit the dle20, as said above the plane is designed around this engine, the motor fits perfectly in the bulkhead and the predrilled motor mount holes line up for perfect dle 20 fitment. As we all know arfs use crap hot glue on builds and it is always a good idea to go over what joints we can, because of this I decided to glass and epoxy the ply motor mount and add a bit tri stock where I could, pictures are below.
I then fitted the dle 20, it was hassle free and a perfect fit. I then plumbed and fitted the tank, the instructions are a bit off here and show on one picture the throttle servo in front of the tank and on the next the servo behind the tank, on my model the laser cut holes on the fuse dictated that the servo goes behind the tank. it also showed the throttle servo and carb throttle arm as being the opposite way up from the way I have fitted mine. This results in a poor throttle geometry that will result in poor throttle control so I fitted mine the way I did. There is no throttle linkage supplied it seems, I will come back to this later in the build.
Although the model came with tank etc it only came with a small amount of gas tubing for use inside the tank, I happened to have 4mm blue gas tolerant tubing that almost matched what was supplied and what looks like is on the instructions so used this to complete the tank set up. More will follow.
ID:	1739075   Click image for larger version
ID:	1739076   Click image for larger version
ID:	1739077   Click image for larger version
ID:	1739078   Click image for larger version
ID:	1739079   Click image for larger version
ID:	1739080   Click image for larger version
ID:	1739081   Click image for larger version
Old 03-15-2012, 10:33 PM
nitro wing
even though you have a somewhat bleh, whatever design, you 'll likely find yourself having alot more fun with it, over the CG Sukhoi or SIG Bipe for sure.
Enjoy [8D]
Old 03-16-2012, 05:58 AM
coronabob
My Feedback: (10)
I have the Redwing one. I must warn you that the motor mount on mine was not up to snuff. The DLE20 shook violently since the top rail of the mount pretty much 'flapped' around providing no support. The top rail broke after 2 minutes. I ended up reinforcing the entire front half of the fuselage with a slab of plywood. I have flown it one time but needed to do more work to it all due to excessive vibration. I am going to fly it again this afternoon.
Old 03-16-2012, 11:40 AM
raydar
Had read that the motor mount was a weak point on this model, was hoping glassing would help it last longer. I also read there is a version two with a stronger motor mount that extends to the wing tube, I do not know if this is true. I have no idea what version mine is if there is two versions. Hope it lasts as dont want to remove covering to strengthen.
Nitro wing I hear you, I have read that this is not the best 3d profile out there. I looked hard at the swanyhouse mojo 65 and at the balsastore sbach but I was wanting something quick to get in the air (arf) and at reasonable cost, unfortunatly being in the UK there is postage and customs charges that start to add up, plus they arekits. If I get bit hard with the 3d bug a mojo will be bought and built in the future, but for nowjust want something I can get flying in a week.
Old 03-16-2012, 01:57 PM
raydar
Fitted the landing gear today, was pretty straight forward. The alloy gear will be up to the job and is not to heavy. Only issue was that one off the cap head bolts for the wheel axles was to short? Lucky I had a bolt that fitted.
Also fitted the tail wheel, it was a PITA. Every time I tryed to tighten it to the fuse it started to bind. In the end I drilled out the mounting holes and used a couple of washers to space it out from the fuse at the mounting screws, def could be better. Oh the instructions also say to drill a 6mm hole for the tail wheel, I used a 5.5mm drill and found it pushed in nice and tight, 6mm would have been to loose.
ID:	1739546   Click image for larger version
ID:	1739547   Click image for larger version
Old 03-21-2012, 02:24 PM
raydar
Got this thing ready to maiden, have been spending so much time trying to get it ready to fly quickly I have not kept up with updates. Anyway hope to maiden tomorrow, does anyone out there have this model and if so where is the COG? Instructions dont say and if balanced at the wing tube I think a pound plus would be required up front?.
Old 03-22-2012, 12:41 PM
raydar
Maidened this plane today, pleased to report that the model is still in one piece, well almost, the spats are destroyed, no suprise as my flying site is badly rutted at the moment due to trials bike vandals.
The model flew with bags of power with the dle 20, straight up. The engine mount is still in one piece, glassing and reinforcing is a must as the vibs of the gasser are pretty fierce on this skinny airframe. The dle 20 ran well, no mid range burble but a slight hesitation from idle to full throttle sometimes and to get a reliable transition had to be set a bit fat on the low end so four stroked a bit at idle. The rxcel ignition curveof the dle 20 is stupid, you give the throttle a blip as you come in to land and suddenly you are doing a fly by, also annoying when doing other manouvres. I have a dle 30 ignition not being used at present, I am going to fit this instead to the 20 engine.
Was not sure of the COG of this model as the instructions make no reference to it?. Read somewhere to balance on the wing tube, but at that I would be adding 1 pound plus on the nose to balance with a empty tank, not good. As the wing tube is pretty far forward I decided to add a bit weight but not the full weight required to balance on the tube, put 10 oz on the nose. Inverted the nose dropped so hopefully the weight is not required, I will start removing it slowly tomorrow. The plane weight was 8 pounds 8 oz WITH a full tank and 10 oz strapped up front and a 180 gram life battery. Will give a final weight when the COG is finalised and with a empty tank when I can, if I can loose the lead it will be about 7 pounds 6 oz dry, not bad. If I cant loose the weight then it will still be a fun model but defeats the point of buying a profile!.
I have pictures of the assembly and planned to see through the build on rcuniverse but due to spending every spare minute of my time trying to get this plane flying for my day off that fell behind, but i will post some up in the next few days along with any issues I had so if anyone else gets this model they dont have to make the mistakes I did lol.
Last thing, this plane so far is great fun, even with the extra weight I plan to loose andthe weird dle 20 idle issues this plane is a hoot!. If I can loose theweight and get her to flystraight and true inverted she will be a great plane, more to come.
ID:	1741502   Click image for larger version
Old 03-23-2012, 12:38 PM
raydar
Flew again today, really starting to like this plane.
Before I went to the field today I swapped out the dle 20 ignition for the 30 ignition, idle is more predictable and far more user friendlyfor sure but the engine was vibrating a bit more, will check the static timing in the next couple of days. Alsoepoxyed a bit 1/4 balsa stock to the other side of the engine mount for added security, still have not experienced any failure of the engine mounteven aftertoday.
Managed to remove one of the pieces of weight up front and found the model to be far better inverted, think I still need to remove the last bit but windy weather stopped me flying as much as I would have liked. The weight removed today was 6 oz 7/8 so taking that off the last weigh in takes the weight to 8 pounds 1 oz WITH A FULL TANK. There is still approx 4 oz on the nose that I think wont be required so 7 1/2 pounds dry is looking like a possibility, yeeha.
The landing gear has had a rough time due to my bad landings and the rutted field, plenty nose overs by me. This caused the gear to wear into the wooden gear block and elongate the holes. Landing gear was removed and hole filled with epoxy ready for a new hole to be drilled when dry, easy fix.
Got a picture of the model at the field, you can see the landing gear swept back before repair. The picture makes the wings look alot smaller than they are so I have included a picture of the sbach wing next to a set of 30cc pilot yak 26% wings that can 3d at 12 pounds.
Obviously this model is not going to compete against a mojo or be the 3d choice for the advanced 3d pilot but for a newbie like me it is great fun and hovers at 1/4 throttle with balistic pull out.
ID:	1741828   Click image for larger version
ID:	1741829   Click image for larger version
ID:	1741830   Click image for larger version
Old 03-23-2012, 09:46 PM
raydar
This is the newyakversion that is going to be availible from april onwards, it seems they have sorted the engine mounting and gave the model a bigger wing, while keeping to the same weight.
Specifications:
Wing Span: 65″
Length: 61.1″
Wing Area: 1029 sq. in
Flying Weight: 6.8lbs
Engine Size: 20cc
Will be getting oneof these when they come out, the wing loading is looking good for a ARF.
Old 10-21-2012, 03:21 AM
AussieBattler
Hi Guys, this is my first post on rc universe although I have picked up a lot of useful tips for my builds by reading your forums.
I have had a couple of these profile planes and yes the sbach is very week around the engine mounts and mine used to shake that much that it eventually fracturedsome of the internal bulkheads to the point where it looked to be just plane dangerous, so this is my fix.
I found in the original build that in order to get the CG anywhere near the right point I had to mount the DLE20 way forward on the mounts. I picked up the front bolt hole one the nose for my rear engine mount hole and drilled anther hole for the front engine mount.
This put the recess in the fuselage for the exhaust out of position, but no problem as I still needed more weight up front for the CG I cut two engine mount packers out of 10mm x 6mm flat the full length of the ply mount strips. The CG was perfect. If I have to add weight, I preferit to also add strength and thisdid the job perfectly.
Anyway some hundred and fifty real hard flights over five weeks of holidays, the nose finally let go. The only thing holding the engine to the plane was the throttle linkage and a couple of pieces of broken ply and balsa; I am lucky I only live about a mile from the local club field so guess what I do every morning.
Off to the local boat repair guy I went and got some 1.6 mm checker plate aluminium and, cut out two plates, one for each side of the fuselage, from the nose right back to the front wing mounting. I had to cut out the checker plate for the leading edge of the wing so that it would still bolt down onto the side of the fuselage. Next I glued the checker plate on with Sikaflex marine adhesive, moved the engine back to the original position and cut down the two engine mount spacers to suit the length of the DLE20.
The CG is just about spot on, I still have to do a couple more flights for final trimming but it is very close. The flex and vibration is gone from the plane, the polished checker plate looks great and I figure it is good for a couple of hundred more flights. I am going to do this fix to from brand new on all of my profiles.
The Aussie Battler
Old 10-22-2012, 09:54 AM
coronabob
My Feedback: (10)
ORIGINAL: AussieBattler
I have had a couple of these profile planes and yes the sbach is very week around the engine mounts and mine used to shake that much that it eventually fractured some of the internal bulkheads to the point where it looked to be just plane dangerous, so this is my fix.
This put the recess in the fuselage for the exhaust out of position, but no problem as I still needed more weight up front for the CG I cut two engine mount packers out of 10mm x 6mm flat the full length of the ply mount strips. The CG was perfect. If I have to add weight, I prefer it to also add strength and this did the job perfectly.
The Aussie Battler
I too bought a SBach. It has a weakest engine mount I ever saw. It shook so bad that the gasoline turned to foam and the DL20 could not sustain a run. Even after I reinforced it with hardwood raills and plywood, the engine continued to suck in air and did the hiccup making its flight not at all enjoyable.
Please post pictures of how you did your aluminum mod. I appreciate it very much.
Old 10-23-2012, 05:12 AM
AussieBattler
No problems, I will get on to it tomorrow. It’s  getting a bit late over here at the moment.
Fitted the Sbach out with Savox 1256's with a 1258 on the throttle last night (a little bit of overkill I know but I have got a 50cc yak hanging in the shed – wanted to try the Savox’s).
I gave it a fly today and I am happy with the servo’s and the plane is rock solid with the aluminium plate but it with a 16 x 6 JFX  it fly’s more like a sports plane.  I have got a 7 x 6 to see if that improves the thing because I bought it for a 3d practice plane.
 I’m just starting down that route, still heaps to learn and given I live in a remote area with no other guys in the club into 3D to learn off its forums, internet and Sim for me. I think transmitter set up will be my next challenge.
If you have any suggestions on the prop I would appreciate it
Old 10-25-2012, 12:12 PM
coronabob
My Feedback: (10)
Thank you for your pictures. Your mod is awesome.
For the sake of those who follow this thread, below is further instruction I received from AussieBattler.
Anyway the pics of my 20cc profile Sbach and this fix I did to rectify the excessive vibration around the nose, mine actually fractured and I nearly lost the engine out of it in flight,and the poor as hell landing gear mounting holes.
I used 1.6mm checker plate aluminium, cut out to the shape of the nose right back to the wing mounting brackets and cut slots for the Zip ties. Two plates of course;one for each side and used Sikaflex marine adhesive. Sikaflex is incredibly tough stuff and flexible so it will absorb any vibration. Just strip off the covering so that the aluminium is bonded to the timber.
If you like you can add a bit of epoxy to any identified bulk head/ribs while the covering is stripped away. Use clamps until the Sikaflex sets, no screws required. This fix just about balanced the plane perfectly so I could take off the weight I had added before this fix to get the CG right.
The plane now idles without the nose looking like it wants to shake itself to bits, believe me it will, the landing gear is rock solid bolted up to the checker plate with 5mm bolts instead of the 3mm ones supplied.
I have got about 10 or so flights on the Sbach since this fix, and I tend to slam the sticks at full throttle and I do not think a I will be able to break this thing. In my opinion a great plane – cheap $165 from SDS hobbies; capable of 3D if required, can be flown like a sports plane if you feel like a change of pace and if it ploughs into the deck you do not have to take out a mortgage on your house for a replacement. Just good flat out fun.
ID:	1814740   Click image for larger version
Old 10-26-2012, 09:17 PM
AussieBattler
I have had a thirty odd flight on this plane now, just about maxed out the throws on all surfaces and have gotten used to the savox servos. Compared to the last servo's I now fly with the plane and do not have to worry about what i think is refered to the latancey of the last servo's response time of input at the transmitter.I do not think I will go under the 18kg servo rating of the control surface servos the plane just snaps and feels so positive.
I have read that the savox servos are pretty power hungry but as I run single A123 and an IBEC for the ignition I was keen to check the amp draw on the system. The old servo's approx 450 ma per flight - the savox about 300ma per flight. I am no tech head when it comes to analysing things but It must be like putting an outboard on a boat -15HP might push the boatalong OK flat out but it will use twice the fuel and wear out three times faster than a 30HP would do the job.
Anyway have fun and fly it like you stole it
Old 02-25-2013, 12:26 AM
stssa
So how are these planes holding up? I am getting ready to order the Yak 54. I just wanted to hear from folks how are the motor mounts doing? Chinese manufacturer is selling them for $124 or combo deal with DLE20 $313 EMS shipping is about $120 to Turkey where I am at. Doesnt look bad.
Old 04-29-2015, 01:39 PM
davecrash
I just ordered one, V3 now. How are they holding up? I see its been awhile since any replies.
Old 05-08-2015, 09:16 AM
davecrash
Mine showed up today, man is this thing huge and lite. The tri stock is on one side of the engine mount already. Doesnt look like they have added a tube to the fuse yet but cant tell for sure. When/if I break the fuse I will open it up and add a tube.
ID:	2094657   Click image for larger version
