Aeroworks Extra 300 / 3W-50
I am building an Aeroworks 50cc Extra 300. I have a 3W-50 that Is broken and runs great. Does anyone have this airplane/ engine combo and if so how did you mounth the engine. I have all the wholes drilled but just trying to figure out the final installation surrounding carb orientation and mixture screw access. thanks
My Feedback: (9)
RE: Aeroworks Extra 300 / 3W-50
Sorry, but mine is DA-60 powered. I can tell you i had to remove quite a bit of firewall for carb clearance. My needles stick straight up in the center of the cowl. So I just put a fuel dot there and can reach the high and low through that opening. Close as I can get for you.
David
David
