Funtana S 90 Prop size?
I was given one of these, it has a Hacker 90ESC and I believe a C50 Hacker motor. The prop on it is a 22x12 APC and for some reason I feel it is too much prop. I haven't been able to locate information on the motor as to what prop sizes are recommended. It also has 3 servos in the tail. I dont have batteries for it either, not sure if I should use 4S or 6S packs, as 3S dont work, the motor spins for like 15 seconds and winds down quickly, and that is without the prop attached.
BC, CANADA
RE: Funtana S 90 Prop size?
try 20x10 or 22x10
I am not a large electric pro, so just a bit of a guess here, prolly needing 4-5000 mah 8 to 10S also? RCG maybe a better site for info
Thats alot of power for that thing
FL
3kg to 4kg
C50-15L + 3,7:1
16-24 cells
12x7 to 15x13
Aerobatic models
up to ~ 4kg
C50-16XL + 3,7:1
24-26 cells
17x11 to 18.5x12
up to ~ 5kg
C50-12XL + 6,7:1
27-30 cells
18x10 to 20x13
betting your funtana is a tank I'm saying geta a watt metter and zero out your thorttel cruve and start 19x10 19x12 see how you like it ..
it would be helpful if you knew the last two number's of the hacker motor C50-XX becouse that's going to relate to the KV rateing and where your power band is .. see chart
lower KV for you would be a good thing if your 3Ding that thing
Also your looking at probly runing 10 cell's it maters the model of hte motor.. appears to bea older motor.. ..
Winds Ri - Impedance Kv (rpm/volt)
L XL L XL
6 0.0038 0.0043 4400 2800
7 0.0050 0.0061 3771 2400
8 0.0065 0.0076 3300 2100
9 0.0084 0.0098 2933 1867
10 0.0101 0.0118 2640 1680
11 0.0125 0.0152 2400 1527
12 0.0145 0.0178 2200 1400
13 0.0175 0.0202 2031 1292
14 0.0199 0.0242 1886 1200
15 0.0277 0.0279 1760 1120
16 0.0261 0.0313 1650 1050
17 0.0297 0.0362 1553 988
18 0.0330 0.0379 1467 933
19 0.0368 0.0435 1389 884
20 0.0403 0.0511 1320 840
C50-15L + 3,7:1
16-24 cells
12x7 to 15x13
Aerobatic models
up to ~ 4kg
C50-16XL + 3,7:1
24-26 cells
17x11 to 18.5x12
up to ~ 5kg
C50-12XL + 6,7:1
27-30 cells
18x10 to 20x13
L XL L XL
BC, CANADA
Zach
the cells would would be AA nicad or NIMH?
I cant see that thing with 20 to 30 of those?
maybe a large glider..
I would asume its a brushless type, maybe the
C50-10 L Acro 6,7:1 Competition ??
maybe like this one? as stated exact motor type is needed, who know what the previous owner put in there?
http://www.hacker-motor-shop.com/e-v...&t=3&c=41&p=41
FL
older motor those charts are old probly refering to Ni metal
I've seen vedios of guys flying that motor with 8 cell's for ruff guess that airplane is probly 13 pound ish maybe heavyer seem's about right
also that motor has differnt model's helps to know the full model to pick your props and cells
but no way would a 3 celll be accataple
you could be right nitro ... on the model
then your prop would be a APC 20X10
OK, I'll pull the mount off and check the model number after I weigh it. I think I can get it off without having to cut off the straps to the ESC, I believe its all tied together on the mount itself.
Its a C50 12XL motor. with master 90 ESC. 12-24 volts, which explains it running for a few seconds, once it dropped below 12 volts it went into cutoff. So what would be a proper pack for this setup.
Holy crap, that motor is $692? That is more than I paid for all my glow and gas motors combined!
On a side note, I downloaded a flew a Real Flight Funtana S 90. Is the wing really as fragile as in the sim? I snapped it off 3 times! It is a very wicked plane too, needs lots of expo and a soft touch.
