PA addiction with HK setup ?
hello
i am planning for a new budget limited PA addiction
so please advice if the below setup will fit this plane or not as i intend to order the electronics from HK
Servos
http://www.hobbyking.com/hobbyking/s..._5g_11sec.html
OR
www.hobbyking.com/hobbyking/store/__10346__Corona_939MG_Digital_Metal_Gear_Servo_2_7 kg_12_5g_0_13sec_.html
motor
http://www.hobbyking.com/hobbyking/s...tor_750kv.html
ESC
http://www.hobbyking.com/hobbyking/s...idProduct=2165
and i will power it by 3cell 2200 mah battery
so any other suggestion specially for the motor as i'm still not sure of it
Servos
OR
motor
ESC
BC, CANADA
RE: PA addiction with HK setup ?
All this stuff will likely work OK, But its kinda like buying a Porsche and putting ford parts drivetrain in it. It will work, but it could be better.
