Sites for gas setup advice.
#51
RE: Sites for gas setup advice.
Hey Ace, if I use the rcexl opto kill, I won't need to take the black and red right? It looks like it has an input for a battery and a separate input for the receiver and then an output for the ignition.. I could be wrong though..
#53
I've found this example but seeing as how we've established that the Spektrum RX and the DLE35 ignition will accept 6.6v with no issues, do I still need the BEC or can I delete it?
http://www.aero-works.net/store/images/upload/plane_large/killswitch_large02.jpg
#56
Awesome, that's what I was thinking too. So I no longer need a BEC in my proposed setup. I figure it like this..
Battery out put 1 - switch - RX
Battery out put 2 - switch - opto kill - splits to IGN and RX
#57
Correct, red and black to ign battery plug and white to rec ign kill port.
But above all if you don't remember anything remember this. Do a timed flight to establish your batteries flight time. I recommend doing one and recharge and calculate. Then do two flights, recharge, add the first time to the numbers and calculate. You really need a good average to ensure the batteries average flight time ability. That is the only down side to the LiFe batteries, when they run out they are out.
#58
Ok thanks Ace, I'll definitely do that. I'm going to invest in a good charger because right now I just have a basic duratrax one that doesn't support LiFe and doesn't have an LCD.
What do you recommend for switches?
As for the red/ black to IGN and white to RX.. That'll be set on the opto kill? Or will I have to splice it about?
#59
I'm sorry skerts, you don't have to seperate the red and black, my bad. You are right in that the RC Excell has a battery plug, reciever plug, and an ign plug.
For the switches I like the miracle dual switches. I get mine from BPHobbies
#60
WA
Check out these switches. I have used all 3 and haven't had an issue yet.
http://www.boomarc.com/en/wallaby-switch-dual-with-battery-voltage-monitoring
http://www.boomarc.com/en/booma-rc-opto-ignition-switch
In my 35% I run 3 batteries. 2 Lipo for the rx with batshare unregulated with high power rx and high power servos. 1 Lipo for ign with a 6v reg.
Same setup in my 30cc just smaller batteries.
#61
Thanks for clarifying Ace, that'll make things easier for sure.
And thanks Chymas, I'll check them out and the miracle switches.
#62
My 50CC setups.
1 2500Mah A123 Battery, dual outputs (all from Wrongwayrc.com)
1 output to a JR HD switch, to the reciever.
1 output to a JR HD switch, to a RC EXcel Optical Kill, to a voltage drop diode, to the ignition.
All are 5x 7955 or Savox 1256tg and a throttle servo
(3 planes, hundreds of flights, no battery/power system issues)
My 100CC Pawnee.
2 2300 Mah A123's one straight to the Power Safe Reciever
1 dual lead wired as above.
My 100CC Pawnee.
