Any issues with this 3d foamy build?
sofar I got the foam down to 170g 31" wing by 31" fuselage not put together yet.
The parts im looking at getting are
Motor:
http://www.hobbyking.com/hobbyking/s...or_1300kv.html
Esc:
http://www.hobbyking.com/hobbyking/s..._BEC_BESC.html
Radio:
Tx:
http://www.hobbyking.com/hobbyking/s...y_Mode_2_.html
Rx:
http://www.hobbyking.com/hobbyking/s..._Receiver.html
Servo: x4
http://www.hobbyking.com/hobbyking/s...cro_Servo.html
Servo splitter:
http://www.hobbyking.com/hobbyking/s...to_5_male.html
Prop:
http://www.hobbyking.com/hobbyking/s...6pcs_set_.html
Some hinges and control horns, epoxy and already got hot glue for glueing servos in (I know hot glue comes off decently when need replacements)
I will be going to the HS when the stuff arives to pickout the pushrod wire and some plywood for the firewall? and probly balsa rod to reinforce it a bit maby carbon if its cheap enough.
Edit: 2s 800mah 10c+ lipo at 39g
Higgins909
Motor:
Esc:
Radio:
Tx:
Rx:
Servo: x4
Servo splitter:
Prop:
Higgins909
My Feedback: (9)
RE: Any issues with this 3d foamy build?
If you have not ordered it yet, look at the JUKA from DWFoamies. Mike is a great guy and he sells the complete package. Just add your battery and RX. There is some assembly required but I think I spent two hours total on mine. I could do the next one much faster. It 's also worth the extra money to have him bevel the surfaces for you.
David
David
