Smoke system question!!
Hey guys I have a 30cc Katana with very limited space inside the fuse. Does anyone have any tricks on organizing fuses to get enough room for me to fit a smoke pump and fuel tank?
You could go with smaller tanks side by side or if you canopy allows, one tank above the other (I have a 50cc set up that way). I also have planes set up for "canister" mufflers that I don't use, and I put the smoke tank in that space.
Thanks so much for the reply and here is a pic of the inside of fuse and canopy. I do have a ton of canister space but it will be very difficult to secure the tanks in that space as it is under everything and is in a built up box that you csn see in the picture.
thanks,
Ryan
thanks,
Ryan
Ryan, Looks like the airplane was built around the fuel tank.
Here is a look at my 50CC MX2. Not much room there, either. I mounted the smoke tank on top of the fuel tank. It is very cramped. The smoke pump is mounted under the engine box/firewall.
Short Video of it smoke in action:
http://youtu.be/Ut05_v60P6g
