Smoke fluid options! Please help!
HiI recently was given and old TME smoke system. It is probably around 20 years old but works great. I still have the original instruction manual which has many different brews for the best smoke fluid. there are many mixes I can do but I want to stay away from mixing and would like to use one fluid to keep it simple. My options are lamp oil, K-1 kerosene used for heaters, or automatic transmission fluid. Can you please tell me what you think will produce the most smoke based on what other people have tried.
Thanks!
Thanks!
BC, CANADA
buy the pre made mix, it just works better than home brews for the most part, super dri is the standard,
these are messy and will work into covering and saturate wood, seal everything very tight and clean after flying
Yeah only problem is that its crazy expensive. It used to be soo much cheaper. They raised the price soo much its insane. You'll be suprised how many people just make their own brews. I am just trying to see which brew is the best because there is no way i will spend that kind of money on what i think is going toward the brand name. I am sure their profit margin is huge.thanks
BC, CANADA
not surprised at how many do their homebrews, but haven't seen any that as good for some reason, what are full size using, they must pour that stuff out by the gallons
