HobbyKing Extreme 3D
Hi there people
Today I received this Extreme 3D plane from HobbyKing.. It's not manufactured by HK itself.. They buy them from Zeta Science..
It kind-off is a flat fuse foamy, but all the electronics are in the fuse non the less.. Looks quite nice
Here is my unboxing of the plane:
https://www.youtube.com/watch?v=5wSJpDdax2g Specs:
Wingspan: 1100mm
Length: 1200mm
Weight: 900g
Servos: 4x 12g digital metal gear
Speed Control: 40A
Motor: 2814 1100kv Outrunner
Required:
4CH transmitter and receiver
3S 11.1V 1500~2200mAh LiPoly Battery
Wingspan: 1100mm
Length: 1200mm
Weight: 900g
Speed Control: 40A
Required:
Hi there people
it took a while because of the weather over here, but here is a video of my maiden flight with the plane
As some have allready noted before.. It IS a bit underpowered with the supplied prop.. So I'll be doing future flights with a bigger prop
https://www.youtube.com/watch?v=78PBnuFwWpY
Hee people
I took out the Extreme 3D again today, and this time I had a 12x6 APC prop on it.. What a difference I was a bit short on sleep, but still.. I liked the flight quite a bit Nice plane!
https://www.youtube.com/watch?v=gGiqXWJ941c
