Hype 3D Fuel Tank ?
My Feedback: (27)
NJ
Hype 3D Fuel Tank ?
Can someone tell me how to install the fuel tank on the Hype 3D ? Does the blue plastic piece have anything to do with installing it ? If not what is the blue plastic piece for ?, It was bagged with the cowl. No instruction on fuel tank installation or support
My Feedback: (20)
NC
RE: Hype 3D Fuel Tank ?
The blue plastic piece is a cover for the servo that sits in the cockpit.
As for the fuel tank, just glue in some small pieces of lite ply from side to side to suport the top and bottom of the tank with enough room for some foam.
You will have a problem removing the that silly grin from your face when you start flying this plane!!
My Feedback: (27)
NJ
Thanks for the reply. That plastic piece was driving me crazy. Could'nt figure where to put it. It was weird it fits the fuel tank perfectly. I installed the fuel tank with some balsa strips, and now I see I can hide the servo with the plastic piece. I am down to installing the elevator and rudder servos with the closed loop system. Went with digitals. Is that the set up you went with ? Are you using the West Engine ? Did you encounter any problems ? Did you use the recommended throws and CG ? Any bad tenencies?
Chris
Chris
My Feedback: (20)
NC
Yeah I went with digitals all round.
Also went with the West engine combo and have to say the engine is a strong one and the pipe provides a fat power band! I am using an APC 12.25x3.75 prop.
No problems so far other then the main landing gear being a little soft.
As far as the throws go I went with all I could get like 85 degs. on the rudder.
I also installed some Du-bro 4-40 pull-pull wire on the horizontal stab. I just looped it though drilled holes in the horizontal stab, vertical stab and around a screw in the bottom of the fuse. and CA it in place. The wire works great.
Things I did not use from the ARF
Fuel tank
pull-pull wire
the plastic servo cover
surface horns
HTH
Fuel tank
pull-pull wire
surface horns
HTH
My Feedback: (27)
NJ
I am also ditching the control horns and the servo cover. I dont mind seeing the bottom of the servo. I did hear the landing gear was weak. I hear there is a carbon one available along with wheel pants. Speaking of wheel pants how are yours holding up ? I am gonna max out the throws too. I have great delection on all surfaces with a minimal amount of gap, worked out well dont think i'm going to seal the hinges Trying to get her up in 03.
Chris
Chris
ORIGINAL: stomper
Has anyone tryed both props on Hype/West combo ? Any differences ? Alan of Weston UK warned about 12.25x3.75
as it "may give too little load on W50T1 and overrev it" ?
ORIGINAL: PlaneCrazzy
on first flights. Definitely item to replace ASAP!
I got LG made of carbon locally as original is on soft side. Either is too soft and flexes waay to much or rips off
ply plate on bottom of fuse. Carbon takes much more abuse without damage to fuse.
Spats are too small, I gave on them after they made 2 nice holes in covering when they turned and fell off on landing....
Wheels touch them and friction pulls out anti-rotation screws. Too bad they are well made but tad too small.
My Feedback: (20)
NC
ORIGINAL: indy
What RPM's are you getting with APC 12.25x3.75 ? I have APC 13x4W on it and it spins @ 12.300 rpm.
ORIGINAL: stomper
I have not Tached this engine yet but going out to fly today and will have to tach it. I'll post what I find later today.
This 12.25x3.75 is one of the recommend props from the manual.
One thing i found Is they don't give a max RPM in the manual?
Has Alan given you a max RPM?
Thanks for the heads up!
ORIGINAL: stomper
When speaking to Alan he was very speciffic about not using 12.25x3.75 (which was my first choice)
but also he didn't give max RPM for W50T1.
Tach yours and post results, actually I am more interested in performance that tach figs.
If it works better I'll switch to 12.25x3.75.
ORIGINAL: indy
Funny enough manual I've got has no recommeneded props in it ?
ORIGINAL: stomper
the instructions do actually say you can use the 12.25x3.75. Ive always used the 13x4w and ive got 13 000rpm of it. Ive now switched to a 13x4 hoping the throttle will be snappy rather than smooth. But that prop is yet to be flow because of one thing or anouther
My Feedback: (20)
NC
Had a great time out flying yesterday! In the sixtys and sunny!
Fuel used was S&W 10%, oil 20% 50/50 with the APC 12.25x3.75 she was spinning at 13.200 which seemed a little high so I fatten the needle and brought the RPM down to 12.400. Even at 12.400 RPM this engine has some power!! I will have to go out and get a few APC 13x4W props and see how this engine likes them.
Yestrday I pulled out my Morris Top Cap that I have a OS 50SX on and I thought it was a strong engine but man the West on the throttle pipe is insane power in comparison!!
I think the 12.25x3.75 prop might be a good choice for break-in but looks like not enough load after about twelve tanks.
I will say that with this plane you are rarely in full throttle mode! It will hang around 1/3 throttle with no problem!
I would still like to know what West thinks the upper RPM range should be on this engine.
Merry Christmas to all and to all a happy flight!
