CA Extra 300L 3D Video
Here is a little 3Ding with my CA Extra and ZDZ 50.
http://www.10374.com/3dbatix/videos/ca330l-1.wmv
hope you guys like it
BC, CANADA
RE: CA Extra 300L 3D Video
looking good Zak!
Looks like it was a little breezy there.you sure have
had the privilege of flying some fine airplanes.Like the smoke,what is your set up?
That is the 27% Extra. My smoke system is made by Megasmoke. I did have to take the pump apart, though, and replace the motor, and the speed control. My dad and I found that the only difference between a smoke pump and a file box pump is well...nothing. We decided to make a smoke pump out of an H9 field box pump, and it was a no brainer. We havent put it in a plane yet, but it should work fine, and only cost around 40 dollars.
Zak my friend i 4 get but that was ARC right? Did you post that on RCTeens...i dont remmeber seeign it
Dan
Try the CActus Aviation Strawberry or Vanilla Smoke. Seeign the plane will be DOD and up next to you let me know how it works.
Dan
