Aeroworks 40 Edge 540T 3D? Any info appreciated
Hi Everyone,
I have my eye on an edge, I read a monster thread about the Aeroworks .60-90 size Edge but unfortunatly it looks like they are on backorder for a few months. From the search I only found a few short threads on the 40 size and they were lacking the info I need. Does anyone have 3D experience with one? I have an O.S. FS-70 that I've been using on my Ex-Treme 330 which weights about 5.8 - 6.3 lbs. (my digital scale varies in that area.. came out heavier than most people's for some reason) and It has enough to pull out of a hover slowly with a 13x6 and I have even used a APC 15x4w per reccomendation of a friend at the field with the same setup and it jumps out of a hover with that. The 40 size edge, according to the aeroworks site says the weight is 5.5 to 6 lbs. so it seems to be in the same ball park. Anyone have opinions or experience to share?
Edit----------
Likewise, any info or opinions on the pacific, or any other edge model in the same class would be appreciated
Edit----------
Thanks.
Edit----------
Edit----------
Thanks.
