YT International ADRENALINE
#202
RE: YT International ADRENALINE
prop nut is OK (its supposed to be a safety thing UUMMM what would you rather be hit in the face with a plane with a spinner or one without... NEITHER!!![:@]
#205
I have a standard muffler on it but it is being changed this winter to a hatori 698 pipe.
Anyway back to the Adrenaline
#206
I have put in some more flying since last week to try and adjust/trim the model.
The CG is now 153mm or 6 in. behind the saddle LE (from 145mm) and no deterioration in pattern precision has been detected. The plane now likes walls and tumbling even more and the harriers require almost no throttle to keep the tail down. So far so good.
Kris1, I too think that the maximum rearward CG on the instructions is not too far back afterall. However, I cannot shift the CG anymore in small steps, since moving the battery to the next available clamping location aft (the wing bolt mount), will shift the CG way beyond 165mm or 6.5in. This is a leap into the unknown. Has anybody flown aft of 6.5in and lived to share the experience??
I keep having two nagging problems and any help from you knowledgeable people would be appreciated.
First, I cannot lock onto a nice inverted flat spin -one of my favourites. With idling throttle, the plane will do it but will fall relatively rapidly. Increasing the throttle to increase spinning rate and halt altitude loss results in an out of shape hovering tumble no matter what kind of aileron deflection I give. I have not managed to find a sweet spot on opposite aileron yet (does it need it anyway for flat spins?) and I’m starting to think something else is amiss, such as too much down elevator throw (I do all spinning in 3D rates, 45-50 deg.) or again forward CG. Do those of you who get nice hovering spins care to share your set-up or stick positions (i.e. how much opposite aileron stick and elevator throw)??
Second, rolling inverted and completing half an outside loop makes the plane steer to the right (i.e. so towards its left wing). Not much rolling is involved; I have checked elevator throw alignment and its is dead on. Its is more like a yaw problem. Could this be some sort of left/right-thrust effect (rudder being in clearer air inverted so yaw more than upright, etc..)? Upright, the right thrust seems to be about right. Any useful ideas?
#207
didnt manage to get any videos this weekend, broke it!
try again next weekend. Im sure Dave will enjoy posting pictures of the damage.
#208
Why should anybody enjoy someone elses misfortune?!? I had a close call today myself, and so did practially every other person at our site in one way or another. At least yours is repairable. Was there any other damage besides the firewall? If not then it's a pretty sturdy plane if it can survive a 15-20 feet vertical drop right onto the nose. Hope the crankshaft isn't bent either.
#209
no, its ok otherwise.
havnt done a lot of repairing yet, i was annoyed that I only got 2 minutes flying so Ive spent the rest of the day flying my shockflyer!
#210
How did ya do that?[X(]tom
I tested my Adrenaline today and because my engine was running with a high idle the plane did'nt want to come down slow so i harriered down on test flight and second flight.I have a Saito 100 FS and i thought it would power it but it did'nt have enough grunt to pull out of a prop hang.So im going to put a smaller prop ont it to see if it improves it but if it don't work it's down the model shop for a YS 110.
Adam
Adam
#211
Was flying on 30% instead of 15, didnt richen the engine enough cause it seemed allright on the ground. Cut when I was prophanging at maybe 20'. Was a good 2 min!
#212
after flying my Adrenaline at the weekend i found that the Saito 100 did not power it enough so I have just got a YS 140 FZ for it this should pull from a torque roll easy with no problems
Adam
Adam
#214
i can do a fast one not too badly its just get confusing when the plane is belly in . Anyway im getting the YS 140 FZ bolted on later in the week hopefully ready to test with a 140
Adam
Adam
#216
Tom,
Sorry to hear of your unfortunate accident with the adrenaline. Looks like it is repairable? How does the cowling look? If it is too bad to use let me know and I will sort one out for you at my expense. Cant have a young hot shot like you flying one of my planes without a nice cowling
#217
thanks for the offer,
the cowl isnt broken at all, just need a new spinner and prop... lucky the motor wasnt broke. I was more annoyed I couldnt fly the rest of the day than that I had crashed it! The only damage is the firewall.
I have a video up until just before it hit the ground, just gotta put it on my website. Will get decent video hopefully next weekend!
#218
Dead stick again today! broke undercarriage a bit but managed to get some video. Was flying high because I was scared the motor would stop, also it was quite windy... that enough excuses pete? Dave will post the video any minute...
#220
The video from last weak is on my website,
www.cwgsy.net/private/tdavid
2 other videos on there you might like of a shockflyer aswell.
Still waiting for dave for the other one, I think hes gonna be putting some pearl jam in the background for me.
#221
Here are a few pics from sunday, hopefully the video will be on soon. I have seen it now, not too sure about the flying but the camara work and editing is quality! Dont think Dave got the bit about Pearl Jam either.
#222
OK, reasons (excuses) for the delay in getting the vid done. Film shot Sunday. 2 days working in Jersey on Monday and Tuesday. Out on Wednesday night. But here it is. I didn't know Thomas wanted Pearl Jam, but I think it's come out ok with what it's got, and I'm glad Thomas likes it. Just whack this address into the address bar, right click and Save as:
www.guernseymodelclub.com/videos.htm
Happy viewing!
Happy viewing!
#223
IL
Hpergm, I am interested in your offer to share the drawings you made for this belly-pan modification... any way to email them to me?
Mark Grabowski
[email protected]
Mark Grabowski
[email protected]
#224
thanks dave,
would be nice to know what people think of the video? I rekon I need more practice before the next freestyle champs, and I need to sort that engine out...
