Show your overpowered plane...
#178
LA
RE: Show your overpowered plane...
I might have a winner. I don't actually have this combo yet but I am seriously considering it. Hangar 9 frenzy 100 with an os 1.60 2 stroke. Every thread has said this plane is severly tail heavy to the point of having to add like 16oz to the nose so this engine should be just the ticket. For those of you not familiar with this plane the auw is supposed to be between 6 and 9lbs with 9lbs being with an electric setup. Hangar nine calls for a 61-100 2 stroke.
#182
I will assemble my Harrier 90 this autum and it will be powered by my ASP 180 fs. I expect it to achieve 2-1 in the thrust-weight department
#183
ORIGINAL: Kostas1
NAHHHHHHHHHHHH...........[>:][>:][>:][>:][>:][>:]
BABY I WON YOU..........ENGINE IS OS 91 FX BEAST.........yiouhooooooouuuuuuuuuuuuu.........
ORIGINAL: UCD46@SAITO
Ucd 46 with a Saito 100 , 14x8, 15x4w prop!!! a total killer!!!![>:]
I don't know what your so happy about. Two strokes suck
#184
Yeah, I have the 91 FX too and it is by no means a beast at all. I was very dissapointed by its stock power. After fitting a Tower 75 muffler and a 60L carb plus some dremelwork on the sleeve it became much more powerful, plus the Tower muffler saved 50 grams off the weight. Stock 91 FX is weighing 770 grams and an YS 110 is lighter and alot more power
#186
My brother´s Fliton Edge Freestyle with a G-26 Zenoah, the weight was way too much for the poor landing gear, looking for a replacement.
#187
YOU had an earlier one.....new ones are IMPROVED!
And
as for "2strokes suck" maybe you must think first before you reply?OK?
Beauty is on the eye of the beholder.....[8D]
And
#188
ORIGINAL: Kostas1
And
And
No beauty is in the torque for 3-D flying. RPM isn't what you need for a U-Can-Do
#189
Kbless I will agree 4 strokes are nice for the torque, but there is no reason you cant do the same hover/3d stuff with a 2stroke. Lots of the profile bros use 2 strokes. I like em all, cept turbines unless its full scale and I aint buying the fuel.
#196
CA
I think I'm in the top 2 this is my world model t-34 with a 120 YS SC. It is fricken unbelievable it was reinforced and still bend the wings in a pylon turn. Take off roll 4 inches, handled and tracked like a pattern plane, sounded like a John Deere on steroids.
Keep the planes coming.................
#199
WA
How about a TWIST 150 with an OS 160fx...
Will hover 3 clicks above idel..
GREAT inverted flat spins up and down with the throttle
#200
HI ! how about a funtana 40 with a 91fx + bisson mufler + perry pump .It is the most powerfull combination off all my planes
