Show your overpowered plane...
#126
Location: out country, somewhere, US MINOR OUTLYING ISLANDS
RE: Show your overpowered plane...
Now I know this shouldn't be in the 3D section, bu this is really over powered
Watage foam Mirage 2000 (auw 1Lb) with 2 x 17Lb thrust turbines . . . . . . . .[8D]
Of course, where to put the fuel is a major issue.
#127
Hi,
Ive just built A .90 Tiger Moth and put a ST2300 up front with a 16x10 prop, only problem is getting it slow enough to land........
Johnny
Johnny
#129
Banned
I've got a Galaxy P-51D with a 68 inch wingspan that's supposed to take a .60 but I put a Super Tigre .91 in it with a 12X7.5 three bladed prop. It did 80mph in level flight but it seems the covering is coming off. Any suggestions????
#130
My Feedback: (17)
I got a Mini magic extra that weighs 2lbs 1oz with a OS 25FX on the nose that puts out 4lbs 8oz's of thrust, we figure she does close to 80 in a full throttle pass
A future project ill be doing soon (hopefully) is a 110 size Katana with a Roto 35 or a ZDZ40
#131
hi shaun russell
i just recieved my funtana 90, ill be using 1.60 fx, perry pump and bisson pitts muffler,
anny suggestions or tips that you want to share ?
thanks
thanks
#132
My Feedback: (15)
FL
ORIGINAL: RED DEVIL 300S
hi shaun russell
thanks
hi shaun russell
thanks
A 1.60FX???!!
I would highly suggest you beef up your plane. Check out my FT90 site at http://derrick.myphotoalbum.com
I have a complete build of one I have. Maybe it will help you some.
#133
Twist on floats with a tower 75, is my most over powered. Its a rocket, I had a OS 70 on it but with floats its ~6.5lbs. The tower 75 is so far just as good as any OS I've ever owned.
#136
Actually I bet thats a good combination. I have a saito 82 on my Harrier 46 and it has verticle just slow. Its a heavy plane mine is ~6.5lbs. A true 46 2 stroke would really Vaccum on that plane.
Just a thought... This same thread would be interesting in reverse, the most underpowered plane. Excluding foamies and sailbirds. I guess my least powerful was a FP 40 on a Duraplane.
#137
My Feedback: (17)
Just bught a OS 91FX for my GP Extra 300 .40
I had the 46AX on it before and it wasnt enough + i had to put about 6OZ of lead on the nose to balence it with the battery under the fuel tank.
#145
I had a scat cat quicky 500 racer with a OS .46vf rear exhast race engine on a tuned pipe. 4 lb aircraft maybe 12 pounds thrust. It was crazy. would go verticle with a few clicks of throttle.
#146
Extremeflightrc.com 87" Yak Electrified. 4800 watts and 15lbs ready to fly.
[link=http://epowerflight.com/Media/87yak/SEFFYAK.wmv]18mb 87" Yak[/link]
#148
FL
I have a Great planes Easy Sport 40 with a Supertiger 91 in the nose, it is pretty impresive even though it is not an acrobatic plane.
Weskel
Weskel
#149
Weskel, thats pretty overpowered. I had one with a ST45, and it was plenty. You know an easy sport is a great second plane, IMO better than a sig 4 star or golberg tiger. I miss mine but the wing decided to come off in an outside loop. Talk about a dart with no wing, broke the engine in 3 pieces.
#150
Fliton eXtra 330 Freestyle with a OS91 FX 2 stroke running on APC 15X4W. It's a ballastic machine.....
It pulled the whole plane so hard that after 5 flights, the whole firewall block was shaky.
Made some reinforcements and the plane is excellent!
