Extra 260 27% Hangar 9er
#3376
KS
RE: Extra 260 27% Hangar 9er
ORIGINAL: tkapfer
Finished and ready for maiden flight.
I have all the bells and whistles, so I'm sure everyone will give me hell.
It weighs in at 16 lbs and 1 oz.
That's with the following:
DA50 engine
MTW 75K Cannister Muffler
(3) DS8711 servos in the tail for stabilizer and rudder
(2) DS8711 servos in the wings
(1) DS8711 servo on the choke
(1) DS821 servo on the throttle
1/4 scale Great Planes pilot mounted in canopy
Smart-Fly electronic fiber kill switch
Spectrum AR9100 9 channel receiver
(2) Spectrum 2700mah 6V batteries on the receiver
(1) JR 2300mah 6V battery on the DA Ignition
If it doesn't fly well, I can adjust as needed.
I don't tend to fly 3D or all those special stunts. Mostly normal flying with some loops and rolls. That's about it.
DA50 engine
I checked out your model photos. That SkyMaster looks pretty cool. Send some video or photos of your new plane if you can. I need to upload some photos of the stickers I put on mine..."Get in, Sit Down, Shut up, Hang on!" and the Hawaiian girl.
#3377
This is excellent news as your outfit is nearly identical to mine but mines not quite finished yet, I was worried about weight. I think mine only differs in servo choices, no pilot, and all 2700MaH Li-Ion batts for Ignition and Rx. I can't wait to hear how she flies.
#3379
KS
Nice, clean, well organized set up! Thanks for the pics. Make sure you range check your Spektrum with the engine running. I have not had any trouble with mine...so far. You might want to rethink the Spektrum installation though. [:'(] The manual says to mount the extra antennae 90 degrees (like on the fuselage side wall) at least 3 inches to the main receiver. I just don't want to see your next photos of a crash. Also, that big engine really shakes the plane so I wrapped my receiver totally in foam escept for the antennae.
Good luck, Thanks, David
#3380
IA
I actually have 3 receivers mounted with this receiver. It will take up to 4.
1 by the receiver like in the picture, 1 on the side of the fuselage by the wing tube and 1 back in the tail section.
They are all pointed in different directions.
I also do have 1/2 inch foam underneath the receiver. I'll see how it initally does.
IA
My maiden flight was this morning. 2 GREAT flights. Only needed 1 click of aileron to trim out. The wind started to pick up today, so had to cut my 2nd flight a little short. The motor took some turns to start initially, but started on the 2nd flip on the 2nd flight.
Here are some more pictures:
#3382
KS
Congrats on a great job! I really like your decals! And congrats on a successful first day of flying! I now have about 4 hours and 43 landings on mine. I dinged two props early on: first one I hit a rock or something on our rocky strip while doing a wheel landing and the second while dropping it in from a harrier landing. I won't be doing those two things again anytime soon. It does great 3 point landings though. I'm pulling a wooden 23 X 8 Mejzlik.
I only had trouble starting my DA50 that first day(until it got primed). Since then I choke it first flight or if it has sat for 45 minutes until it first fires(usually about 2-5 flips) then it usually runs on the second flip after that. Sounds like your off to a great start. Good flying! I would say, "keep the greasy side down," but it doesn't really have a greasy side, eh?
I put a T fitting on the end of my vent and stuck a screw in one end of it (I say it's to work like a pitot tube to pressurize the fuel tank). The real reason is so I can recapture any overfill into a line a stuck through the lid into a baby food jar. That way the gas doesn't kill the grass. I also need to redo my fuel dot. Last flight at our clubs open house, it came slack on the inside of the cowling and melted against the exhaust.
I am anxious to get home so I can finish the smoke system installation. I'll have to upload some photos someday.
Anyway, congrats again and great flying!
David
David
#3383
ORIGINAL: tkapfer
When I get some pictures taken, I'll post them here.
I hope to maiden this bird sometime later this week after work or this coming weekend, weather permitting.
Also, had anyone put out some pictures of what was needed to build up the rudder.
I had seen some posts about putting carbon fiber rods into the rudder to strenghten it, but was not sure what they were actually doing. Something about counter balance, but I was not sure what part that was.
CT
Im happy to see everyone is flying their extra 260s!!!Looks like IM the only one still trying to build this plane !
After reading thru the directions and trial fitting the motor ,gas tank ,servo locations ,numerous variations ,I have decided to throw out the manual.
A da 50r with a MTW td 75k is going in this plane .
Many others are flying this same set up but mine will be a little different .
I choose not to cut the length of the muffler instead I opted to mount the muffler as far back as the header pipe would allow .Also I plan to mount 2 servos ,throttle and choke via carbon fiber rods ,to the tray that would have supported the pull pull servo.Now this will leave me with the option of laying my fuel tank flat resting on the origanial servo tray for the throttle ,and also will set me up with more wieght on the tail.
#3385
IA
Spoiler, so the carbon fiber rod you put in went vertical about where my picture shows???
Down to the block that actually holds the hinges?
Or did it go horizontal to give more support?
v
Basically? Sorry for the bad picture.
v
#3386
IA
I kind of laid a c/f rod along where I think you all have said to glue it into the rudder.
Let me know if that is close and if there are other parts to strengthen.
#3387
ORIGINAL: tkapfer
#3389
ORIGINAL: rcpilot_971
Im also building one of these can you put the rudder servo in the tail ?
My Feedback: (50)
Ok thanks
I have A brison 2.4 in it now but still need to hook everything up but I have never ran a gas motor before so I was thinking about putting a saito 220 in it the brison is 2.75 lds and the saito is 2.80 lbs but I wount need the the extra battery the ignition
Thanks Tim
Thanks Tim
#3391
IA
I have 8 flights in on mine now and it flys GREAT.
The DA50 has plenty of power and 2 of my flights today started on the first flip.
I also have experienced the same thing EVERYONE seems to have (delaminated c/f landing gear).
I landing slightly hard with only one bounce and heard it crack.
Luckily I had the aluminum gear at home and just replaced it with that.
I wish they would update what is in the kit since everyone keeps having this problem.
Good luck in everyone else's birds, and I hope you have as much fun as I have been having.
I'm going to be running about 5-6 gallons of fuel through the engine for break-in as recommended.
I also put the 2mm c/f rod down through the rudder to make it stronger. I don't want that problem next.
Happy flying.
Happy flying.
#3392
My Feedback: (13)
ON, CANADA
I saw one of these flying at my club today. 15lb 10oz with a DA/canister setup. The pilot is an intermediate and had no trouble at all with this plane. Predictable glide when landing etc. It appers to be a very nice flying first gasser. It inspired me to go out and get a MVVS/Evolution 45MG for my 74" Ef Yak due to the similar size and wing loading etc.
Dave
Dave
#3393
IA
This is my first gasser and I am soooooo happy so far.
Although I am learning many things over glow engines.
My flight tonight had the engine not running well about half way through the flight.
One of the instructors at the field helped me land just to make sure it got down ok.
After further investigation, we found out that the ignition battery had dropped below 5 volts and the engine was about to quit.
Thank the Lord that it did not.
We recharged the battery at the field and the next flight was great.
Also, the aluminum gear worked great tonight. It won't delaminate like the cf gear.
It's different from glow engines where they keep running with the glow plug.
I did check my battery before the flight and it appeared fine, but did not check it with the correct load as obviously the battery had dropped fairly quickly.
Lesson learned - always check your batteries with a load on them.
Also don't fly too many flights without recharging.
Good luck with everyone else's.
Anyone find any better tail wheel springs than the ones that come with the kit? Mine also broke tonight. It doesn't seem like the stock ones fit very well to begin with.
#3395
IA
Not sure what they are worth, but I'm sure mine can be repaired with some CA.
It just delaminated on one side.
I have the aluminum on now and they seem to be working ok.
Here are some pictures:
#3396
ORIGINAL: tkapfer
#3397
I just ordered this plane and it's on backorder till mid-June.
I have patiently read thru 37 pages of this thread and skipped ahead, hoping that the gear issue was resolved by this page.
Before that, I put a call into Horizon asked if the new batch has a "fix" for this ongoing problem. I'm awaiting a response and have my fingers crossed.
Meanwhile, can you tell me what the general consensus is as far as servo choice and is the previous recommendation of rudder reinforcement still necessary?
#3398
IA
No, they have not fixed the landing gear issue. I just purchased my kit in late March early April and just had this problem with it delaminating after about 8 flights. I put the aluminum gear on and have not had any problems. Although it is a little more weight than the cf gear. My plane comes in just over 16 pounds anyway, but I'm not stressing it with all the 3D, so it should be fine. With the DA50 motor and the MTW 75K cannister muffler, it sounds way cool and is very quiet.
I reinforced my rudder with the c/f rod as you've seen previously. I did not have the problem before reinforcing the rudder, and have not had any problems since. I guess it's better to be safe than sorry.
I have JR DS8711 servos all the way around except for the throttle.
One of the really good flyers at our field said that those servos worked GREAT, very fast and responsive. He said it almost makes him want to go out and get one of these kits as well. Although using that size servo does force you to sand out each mounting hole to make room.
Have fun. Decisions, decisions, decisions.
#3399
Those with DA-50's what Tygon tubing size are you using? Neither the DA-50 manual nor the H9 manual say specifically. Will the small size work OK?
#3400
IA
I'm using 1/8 Tygon. I also have tied off all the ends with the small wires you can buy in packs.
I also soldered ridges around the fittings on the brass tubes on the fuel tank and tied with wires so they will not slide off (inside and outside the tank).
So far everything has worked great with no leaks.
