If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 2 of 146 FirstFirst 12341252102 ... LastLast
Results 26 to 50 of 3637
  1. #26
    Join Date
    Jun 2004
    Williamstown, WV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Extra 260 27% Hangar 9er
    Would this plane be better with glow or gas, with that new Saito 2.20, will it be a gas hog? Thanks!!
  2. #27
    Join Date
    Oct 2004
    -, WY, BOLIVIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It sure wouldnt be cheap and from my experiences with my saito 100, it would bbe dounright expensive, I pay the price on my funtana 90 that I fly soo much and I am only 15, 30% is too darn expensive!!!
    but the da 50 would be cheap fuel wise, I wonder how much the evolution is and whats it's weight and thrust compared to the DA 50?
    anyone know
  3. #28
    Join Date
    Jun 2004
    Williamstown, WV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    heres the specs on the evolution 58 gasser:
    Type: 2-stroke Gasoline
    Displacement: 3.6 cu in (58.188 cc)
    Bore: 42 mm (1.65 in)
    Stroke: 42 mm (1.65 in)
    Cylinders: Single
    Engine (Only) Weight: 1820 g (64.42 oz)
    Crankshaft Threads: M10 x 1.25 mm
    Benchmark Prop: Mejzlik 24 x 10 @ 6,900
    Prop Range: 22 x 10 - 26 x 10
    RPM Range: 1,000 - 7,500
    Fuel: Oil w/Gasoline mix 1:40
    Mounting Dimensions: 243 x 78 x 140 mm
    HP: 8.5 hp @ 6950 rpm
    Cylinder Type: Ring
    Starting System: Electronic Ignition
    Carb Type: Walbro
    Crank Type: Ball Bearing
    and heres the DA50 gasser specs:
    Displacement: 3.05 ci. (50cc)
    Output: 5 hp
    Recommended Props:
    2-blade: 22x10, 22x12, 23x10, 24x8.
    3-blade: 20x10, 20x12, 22x10 narrow.
    Weight: 2.94 lbs (3.13 lbs with stand-off mounts)
    Length: 6.7" (170mm) (total with stand-off mounts)
    Bore: 1.6771" (42.6mm)
    Stroke: 1.3779" (35mm)
    Reed valve.
    Desert Aircraft auto advance electronic ignition.
    Exclusive Desert Aircraft designed cylinder, piston, rod and crankshaft.
    CNC milled 7075 alloy crankcase.
    But heres the thing, the DA is $50 cheaper, but as you may have noticed, the evo has more power, but this engine will come out in may, but the plane will be out for a month before the evo!! Plus, we already know that the DA50 is reliable, and we know nothing about this evo
  4. #29
    drumbum's Avatar
    Join Date
    Jul 2004
    Lynchburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    4LBS its a a heavyweight.. looks like fuji/ Zenoah territory.. stick with the DA
    Lee Durham,
    http://lee3d.tripod.com
  5. #30
    Join Date
    Oct 2002
    Salmon ArmBritish Columbia, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think that the 58 would push the wing-loading up too far. In the MVVS line (manufacturers of Evolution) the new 45cc engine would be a better choice. The 45 is a pound lighter than the 58 with a wide, flat power curve. Factory numbers suggest that this engine is competitive with other European 60s!
    http://www.mvvs-canada.com/products.php?cat=2
    I only wish they gave this plane an 80" wing span so it would qualify for "Big Bird" and IMAA events!
    David Moen
    www.mvvs-canada.com
  6. #31
    Join Date
    Mar 2003
    Memphis, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I always thought that 1/4 scale and up did qualify for IMAA legal size (?)
    Blair
    Extreme Flight
    Aircraft International
  7. #32
    drumbum's Avatar
    Join Date
    Jul 2004
    Lynchburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i think this plane is 20% or 22
    Lee Durham,
  8. #33
    Join Date
    Mar 2003
    Memphis, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Its advertised as a 27%
    Extreme Flight
  9. #34
    Join Date
    Oct 2004
    -, WY, BOLIVIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So u are gonna compete with it?
    anywais I think I will stick with the DA 50, I seems to me that lighter is better, I think that it could pull the plane around very well for how much the plane weighs, I never really liked the look of the evolutioin engines and thought that they weighed alot and were underpowered.
    do you think that Hitec's 5645 digitals will be enough for this monster.
  10. #35
    drumbum's Avatar
    Join Date
    Jul 2004
    Lynchburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BR289
    My bad ,, i wouldnt have thought it, but then again the H9 33% is in the 96" range so that sounds right.. Good point
    Lee Durham,
  11. #36
    Join Date
    Jun 2004
    sarasota, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys my VON EXTRA 260 is legal for IMAC . This one is 35%
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	253788   Click image for larger version.
    http://WWW.ROMANBUILTMODELS.COM
    VON EXTRA 260 35 %
  12. #37
    Join Date
    Dec 2001
    San Diego, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Extra 260 had a wingspan of 24' so at 78" the scale is 27.08%
    Doug Cronkhite
  13. #38
    Join Date
    Jun 2004
    Williamstown, WV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Horizon doesnt want to admit that the evolution gassers are made by MVVS, cause when I called them they were getting mad, becasue I said they were MVVS, and he said that they were evolution factory, made not MVVS
  14. #39
    drumbum's Avatar
    Join Date
    Jul 2004
    Lynchburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: ROMANBM
    big difference, this plane is $379 that one is $2000 ..
    Lee Durham,
  15. #40
    Join Date
    Oct 2004
    -, WY, BOLIVIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    and who wants to cover it anyways?
    the scheme on the h9 is col enough, it could of been a little more agressive though like on the show time 4d, I dont want to think abotut the sfg's though.
  16. #41
    drumbum's Avatar
    Join Date
    Jul 2004
    Lynchburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Banche
    Me,, I would rather build it too ,, but not a $950 kit.
    Lee Durham,
  17. #42
    Join Date
    Jun 2004
    Williamstown, WV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  18. #43
    Join Date
    Jun 2004
    sarasota, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My airplanes are like the lamborgini of the industry. They are for the select few willing to pay the extra price for an excellent quality airplane made especially for the customer in any color they choose. Special care and consideration is put into building my airplanes with extreme attention to details. So if you choose to have an airplane at a lesser value know that you get what you pay for.
    Roman Scarfo
    Builder and Pilot since 1987
    VON EXTRA 260 35 %
  19. #44
    Join Date
    Jun 2004
    Williamstown, WV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Horizon doesnt want to admit that the evolution gassers are made by MVVS, cause when I called them they were getting mad, becasue I said they were MVVS, and he said that they were evolution factory, made not MVVS would someone respond to this its the 3rd time!
  20. #45
    Join Date
    Apr 2002
    Silverdale, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    BANCHE: If lighter is better, why not cut off at least a pound or more and go with an OS 1.60FX or Moki/Mark 2.10? They would save a lot of money, a lot of weight, put out plenty of power, and the plane would certainly land better and perform the slow 3D stuff much better. The DA50 is probably better suited for planes with a bit more wing area. Also, the Extra 260 was the plane Patty Wagstaff flew until the mid 90's in competition, and that is the plane she donated to the Smithsonian. See attached pic.
    BARCC: Are you experiencing technical difficulties, or trying to exaggerate your point (triple post)? You are probably right that MVVS makes the engines, but perhaps Horizon has tweaked the design a bit? I don't know anything about this, but I do have an idea how much it would cost to set up an engine manufacturing plant. It would be much cheaper to design an engine and hire a manufacturer to produce it.
    ROMANBM: You are absolutely correct, excellent-quality and special consideration command a premium price. To be honest, I wonder how you can afford to sell your planes at your price given the quality of the craftsmanship and the amount of work and time going into each one. I have owned a couple of custom-built planes and they are truly head-and-shoulders above the high-quality ARFS I have owned. I have a custom-built 27% Cap 232 with 1250 in^2 wing area, ZDZ40, that weighs 12lbs and is a tremendous plane, lands slower than many trainers. It is 2.5# lighter and 300 in^2 larger than my Hangar 9 Cap 232 was. It had a tremendous amount of power but was scary to land.
    This plane looks very nice and would be quite a performer. It has great lines and probably won't have many coupling problems. I like the plug-in wings and hatch. Hangar 9 is now getting much better at building light planes, and this one will probably continue the tradition.
    Anyway, I look forward to some flight reports!
    Brett
  21. #46
    Join Date
    Oct 2004
    -, WY, BOLIVIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I cant wait for the ef yak, the extra and the st 4d from h9. they all are not for sale yet and they are the three that I want!!! [&:]
  22. #47
    Join Date
    Mar 2003
    Memphis, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Greetings,
    I think most people are thinking Gas because of the cost of running a large 2-stroke, compared to regular gas ( even at todays prices ).
    I am thinking of putting a F.P.E. 2.4 in mine when it comes in.........should be plenty for "Sport Flying", and economical too.
    Blair
    Extreme Flight
  23. #48
    Join Date
    Oct 2004
    -, WY, BOLIVIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yes gas!!!! a saito that big is almost as expensive as the DA 50 and has less power, more mess and more price, by far!!!!!!!
  24. #49
    BoneDoc's Avatar
    Join Date
    Sep 2004
    San Antonio, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How about the new 52 cc Revolution by Brisson? It weighs only 3 lbs, compact, and has 28 lbs of thrust... yeah baby!!!
    Josh
  25. #50
    Join Date
    Mar 2003
    Memphis, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It seems to me that anything 3lbs and under is fine......since the DA 50cc is 2.94lbs.
    Extreme Flight
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
