Extra 260 27% Hangar 9er
#501
RE: Extra 260 27% Hangar 9er
ORIGINAL: Todd L.
In the process of gettin the DA installed on it rite now but i'm not useing pull/pull. It shows in the manual to install the rudder servo in the rear of the fuse if useing a DA.
And about the elevator stab tub being crooked..... I called HH today and they dont think it will cause a problem having the elevator tube like it is. I checke the stabs with the insidence (sp?) meeter and they are dead nuts on 0... They said if I do have a problem they will take care of me.
ORIGINAL: dgeorge
Has anyone flown a Da50 on this plane? I'm interested in hearing about how it flew and if you used the pull/pull rudder ?
PLEAS TAKE A LOOK AT WHAT I DID TO FIX MY YAK AND GIVE IT A TRY. This condition is not a building defect, as these things are jig-built...the fuse just got a little twisted when they covered it. you may want to take a look at your ailerons as well, as they tend to be prone to tweaking from the covering, too.
#502
ORIGINAL: Todd L.
Bodyworks.....Thanks for the tip dude...... But the fuse is not twised, the tube sock it self is in crooked. I wish it was as easy as pulling some covering tight.
The RCU server won't let me show pics, but if you are interested in them, PM me
#503
ORIGINAL: dgeorge
flyin Hawaiian,
What are you planning on doing about the choke setup? I'm thinking about using a servo on the choke and mounting it next to the throttle servo.
flyin Hawaiian,
#505
Guys i got to say WOW what a plane, i love it.. but i have a problem whit the landing gear it already cracked, does anyone know another good gear for thi plane??
Extra 260
DA 50cc, pitts muffler
5 Hitec 5645mg
1 Hitec 425
R770 pcm..
Extra 260
5 Hitec 5645mg
1 Hitec 425
R770 pcm..
#506
My Feedback: (9)
MI
ORIGINAL: Triton 3D
Extra 260
5 Hitec 5645mg
1 Hitec 425
R770 pcm..
Extra 260
5 Hitec 5645mg
1 Hitec 425
R770 pcm..
Some of the guys have been getting the Graphtech gear
Hows the fight performance with the DA? Need more info bro
#507
Todd L, the motor is still in break in and man this engine ROCKS!!, it has power to spare!! i would recomend this engine to everybody, and the rudder servo has to go in the tail. Nice video Tooly..
#508
TX
Did you guys read my post? Are you sure it's a "cracked" gear, versus just the paint cracking. Mine had the paint cracking, but when I look at the gear underneath, it looks fine (of course my Kevlar thread mod might have something to do with that too ).
#509
My Feedback: (9)
MI
ORIGINAL: Triton 3D
Any idea what your flying weight came out to? Cant wait to get mine in the air!!!
#511
ORIGINAL: BoneDoc
Yeah, the gear delaminates....... Nuff Said.
#512
All I want to know is is Horizon going to replace our planes or not maybe some input from Mike would be nice
It is a great plane and I wish they would have supplied a good quality Alumanun Landing gear with it and no one would have a problem
Now I have to send mine in to horizon probebly wait two to three weeks and then hope to get a new fuse and a cowl
and maybe be up in the air by july
This just sucks
This just sucks
#513
VA
It sucks no dpubt about it but at least you know your plane flys good if Horizon does send me a new plane then I will have to build it and hope it doesn't have the same problem as the one I sent in. You can bet on this though it won't have the stock gear on it next time I fly mine!
#514
I figure spending 50 bucks on a good set of after market gear is no biggy compaired to paying 250.00 for a replacement set of retracts most of the ARF Warbirds come with.
Still it doesn't make it rite for H-9 to have this sh*@ty gear in a nice plane like this, and have guys planes get jacked up, or worse after 2-3 landings.
Come to think of it, I think I read posts about Q.Q.'s Yak about this size having the same problem this gear has.. Did H-9 get them the same place ??
#515
This gear issue still has me confused. If the gear delaminates through the bend, it isnt going to twist back and do anything. It'll simply bend more like an alum gear that has bent due to a hard landing.
Did someone actually have one twist back on a normal landing?
#516
My Feedback: (28)
FL
And to clarify as "flyin hawaiian" and I had a little convo on this as well. He and I both own Extreme Flight Yaks and the composite gear on both planes had the gel coat crack and not the gear itself. Are we absolutely sure it's not the gel coat cracking on this 260 gear? I know it sounds stupid, but we all make honest mistakes from time to time. I haven't see pics, but stress fractures in the gel coat I would consider common. I have 6-8 flights in so far and nothing wrong with mine. (can't wait to heaar the 'you just wait' comments)
JP
JP
#517
VA
My gear actually only seperated in the bends until that last fateful deadstick! That did it in along with the left wing tip a couple formers in the fuse, slight bend in the wing tube and my cowl. Horizon will have it back in a couple days so hopefully the next one will be better!
#518
KS
Trinton 3D, Great to here about your flight!!!!
I'm going to take Flyin Hawaiians advise and use a bell crank for choke. I have already installed the rudder servo in the tail. I would also like to know how much your bird weighed.
What did you do about fuel tank placement?
FL
dgeorge
I did mention the tank placement in the thread about the bell crank, but thats kewl! I made a light ply pod. Basically I velcro strapped the tank to a light plywood base and created a 'fuel pod' and glued in mounting braces around the landing gear. With only two screws the whole pod can be installed or removed rather quickly, yet will with stand the G's (I hope . Tank is slightly forward of recommended CG. I will try and take a pic and upload.
#520
ORIGINAL: MMcConville
#521
Hey guys here some pics of my fuel tank placement, landing gear broken, DA 50cc, and please put some locktite on the swivel links i almost lost my baby yesterday..
#522
My Feedback: (99)
TX
ORIGINAL: Todd L.
here's the pic of the off stab tube. Im not to sure what im gonna do about this yet.
Boy that looks like a pretty serious twist. i would do what BODYWORKS recommends on the repair. or send it back to horizon for another fuse. that thing is going to snap on low rate's at the very lowest throw.
#524
My Feedback: (99)
TX
ORIGINAL: Todd L.
LOL!!!!!!!!!!!! Now that I got the elevator tube strait the rubber post is crooked..... Whats the fix for that? Cut the rudder post off and reglue it?
Well for one thing you SPELL straight Wrong
If i told you to jump off a bridge would you do that ALSO!!
#525
TX
BW,
Lighten up . You've been quite critical of this plane ever since the beginning. And for someone who doesn't seem to like it, you're planning to buy it. Was the Yak Perfect when it first came out? I don't think so. I'm confident that Mike did NOT purposely put a weak gear. His preproduction gear probably holds up just fine. When you go into mass production, anything goes.
FWIW, my kevlar thread mod fix most of the delamination issue. My gear didn't delaminate at all where the kevlar threat are put in. However, it did delamiate a little further down. I'm planning to put a bit more Kevlar thread into it.
Mike, when it delaminates enough (as I'm sure in some gears did), it separates from the part that attaches to the fuse, and so the horizontal pressure that taxing and landing will cause it to twist and warp. If all landing is purely vertical, then you're right: it will just bend back and forth. But since there's some horizontal pressure from the forward motion of the aircraft, twisting and failure is definitely within the realm of possibilities.
Josh
Josh
