If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 8 of 146 FirstFirst ... 6789101858108 ... LastLast
Results 176 to 200 of 3637
  1. #176
    Join Date
    Aug 2004
    huddleston, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Extra 260 27% Hangar 9er
    The distance from the firewall to the spinner backplate is (6 and 7/8)inches. That gives you 1/4 inch space between the cowl and the spinner back plate. Here is a pic.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #177
    Join Date
    Aug 2004
    huddleston, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are some more pics of the inside there is plenty of room to mount the tank on the CG if you want to.
ID:	274940   Click image for larger version.
ID:	274941   Click image for larger version.
  3. #178
    John Murdoch's Avatar
    Join Date
    Jun 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bodyworks
    I am still thinking about a DZ160, but I know I will need a 20oz tank to get a decent flight time, versus 12 ounces with a gasser.
    Oh.. A DZ 160.. I thought you meant a ZDZ 160.. I was thinking to myself, Oh My God!
    ~Growing Old Is Mandatory~
    ~Growing Up Is Optional~
    John
  4. #179
    Join Date
    Jun 2004
    Williamstown, WV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Help me!! I'm STILL pondering which motor to buy, DA 50, which will cost ALOT, considering I want a tru turn spinner, and it will need modded for multi bolt, and custom cut for carbon prop, and, I want duralite batteries too. Should I get the Saito 2.20? Dunno help me deside, I dont want the YS 1.60DZ, too expensive. With the DA 50, the gas/oil per gallon, will be about $3.00 mixed, and for the Saito 2.20 I WANT to run Cool Power 30% nitro, 20% synthetic, and that will cost $20.00 a gallon, the DA 50 will cost WAT more upfront, but the Saito will be more expensive on fuel. Plus if I get a DA 50, I want to trick it out, because it would be my 1st gasser, smoke system, lithium-ion, everything!! Thanks!!
  5. #180
    Join Date
    Aug 2004
    huddleston, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I think the jury is still out on what the best engine would be I think it would be the YS160 myself but we will have to wait to see how this plane does with some of the other combos the other guys on the forum are putting together. What ever you choose remember KEEP IT LIGHT! I am running a smartfly regulator and a Thunderpower 2100 mah 2 cell for power to the reciever and servos at first I was worried that the battery would not be big enough but I am running all digital servos other than on the throttle and after 7 flights it only used 137mah on recharge. That is pretty good for a battery that weighs 3 oz.
  6. #181
    Maudib's Avatar
    Join Date
    Jul 2002
    Ashland, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You will NOT want to put smoke on this with a DA50... TOO heavy. You could use lion on the receiver and a 4 cell nicad on the ignition.
    Carbon props are generally heavier than wood... so get a decent 22x8 wood prop (at least to break in) and eith some painting you can do at home, you can make a sweet prop... see attached pic of my MSC painted to match my DV) Mount a 16 oz tank under the wingtube.
    Trickin' would be a CF spinner (or fiberglass) from Bisson Custom Mufflers. Lighter in the nose and trick looking.
    I did a spinner cutting tutorial when I built my EF Yak and Bisson asked to use my pics in their PDF tutorial... see here:
    Spinner Cut Tutorial
    And here is Bisson's Site: http://bissonmufflers.com/
  7. #182
    Join Date
    Sep 2003
    Rural, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well I run my OS 1.60's on $8/gallon fuel and get just under 9k on a 18x6W with it and use about 12-14oz for a 10 minute or so flight. It's not that bad on fuel. Some people make it sound like it cost $5 for each flight or something.
  8. #183
    Join Date
    Aug 2004
    huddleston, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well have you ever done somthing that makes you feel like a complete idiot? I did! when I posted my flight report eighther on this thread or the other one I mentioned a snap off problem well I just found out the cause. I had the control throws different in the radio. DAMN I FEEL STUPID !!! I cant wait to see how she flys now!!
  9. #184
    Bill Killillay's Avatar
    Join Date
    Sep 2003
    Snellville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: EXTRA ADDICT
    Darn computer radios... Been there done that though...
    Bill K.
  10. #185
    Join Date
    Aug 2004
    huddleston, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yea it is a new radio as well. Now I just have to wait for another calm day to see how good she really flys. By the way Bill I posted the measurements you wanted on the other forum.
  11. #186
    Join Date
    Sep 2003
    Snellville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got them and thank you very much.
    Any idea on the lenght of the servo arms that they are recommending? I want to order some for my Hitec's from Air Wild, but I want to keep the length consistant...
    BK
    PS. Which radio do you have?
    Bill K.
  12. #187
    Join Date
    Aug 2004
    huddleston, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just used the arms that came with my Hitec sevos.
  13. #188
    Join Date
    Jan 2003
    Stanfield, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Has anyone considered a Moki 210 for this plane?
    I have one on a Pacific Aeromodel Edge 540T with an 84 inch wing and it flies great.
  14. #189
    Join Date
    Sep 2003
    Snellville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Where you able to get good resolution? Which length arms? There are several...
    Thx,
    BK
    Bill K.
  15. #190
    Join Date
    Aug 2004
    huddleston, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I used the 3/4 inch arms and every thing worked out great. I even used the long double sided arm for my pull pull setup. The new radio is a Jr 9303 I just replaced my 6102 with it so it is a new animal all together.
  16. #191
    bodywerks's Avatar
    Join Date
    Dec 2004
    Tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: ChrisK7
    Moki 210 would definitely have plenty of power and would be a decent engine choice, but it is still nitro and a bit of a heavyweight. If you happen to just have one sitting around, though, you've got your engine for this plane...
    STRAIGHTEN UP AND FLY LIGHT!!!
  17. #192
    50%plane's Avatar
    Join Date
    Mar 2005
    California
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Get a 9C. It is the easyest radio to program and understand what you are doing that I have seen.
  18. #193
    drumbum's Avatar
    Join Date
    Jul 2004
    Lynchburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    man i just looked at your fields website.. all the times i fly are banned.. whats up with that. is it in a church back yard? thats a bummer
    Lee Durham,
    http://lee3d.tripod.com
  19. #194
    Join Date
    Jun 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lee... Join that church NOW! Maybe you could get people to pray for you when you fly.. LOL
    John
  20. #195
    hovermaster's Avatar
    Join Date
    Jan 2002
    Tooele, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I completely agree with Spratrbo about your flying Blair.. hahaha...
    JP you need to come up here...
    Blair and I are practicing all week for the XFC.. the RadioCraft is at his house.. haha
    gg to all, and to all gg...
    -DMS
  21. #196
    Join Date
    Aug 2004
    huddleston, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The 9303 is actually pretty easy to program I just overlooked it in my rush to get the plane done. I am just glad I didn't overlook somthing more vital!
  22. #197
    50%plane's Avatar
    Join Date
    Mar 2005
    California
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: drumbum
    The only times that are banned except during special occasions are after dark and before 12:30 on Sundays. We are near a church, so out of common courtesy we don't fly before 12:30 only on Sundays. The reason we don't fly after dark is obvious. During the Jumbo Fly-in I don't believe that the restrictions will be in place. There will be electric only night flying on Saturday as an event, but will probably be open during the whole weekend.
  23. #198
    drumbum's Avatar
    Join Date
    Jul 2004
    Lynchburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    when is this fly in. im in lynchburg wich is not too far away. see i fly on saturdays too . it looks like they are banned from what i saw.
    murdock,, come to the bible belt you will see what im talking about.. my city is home of Jerry Falwell if that tells you anything... thats how i knew there had to be a chruch there..
    Lee Durham,
  24. #199
    drumbum's Avatar
    Join Date
    Jul 2004
    Lynchburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lee Durham,
  25. #200
    Maudib's Avatar
    Join Date
    Jul 2002
    Ashland, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks like Most of Saturday is banned FROM Sept 1-Jan. 31
    The fly-in is June 17th-19 so isn't limited on Saturday... Sunup to Sundown...
    Unless I misunderstand something...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
