Showtime
Old 03-09-2007, 08:22 AM
  #2026
raideron
raideron's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Showtime
hellblastervolly... Yeah it should work out... I used the "finger" balance method when I
first did mine, so my 6v was about as far back as I could get it(Frt of servos) I'd say she
was a bit tail heavy.. breath on the sticks and she'd jump,(30% low rates, 70%expo)
hands off invert she'd climb better than most trainers upright :-0.. She still came home
after 3 flts like that.... My thought's.... Ohh Sh_t this is not going to last long....[]
It was an UPS deal on the used Yak.... MMmm.. the 110 and a servo on the S.T. is from
that package too[8D]... I just love those prices... But it was sad at the start.... But I
learned to live with it
raideron is offline
Old 03-14-2007, 05:51 AM
  #2027
JPal101
My Feedback: (32)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, I tried to mount my YS110 with a Slimline pitts muffler with the stock mount and it does not fit. Did I read somewhere that it will fit if I use a Hyde mount? Probably would be better off with the Hyde anyway.
JPal101 is offline
Old 03-14-2007, 07:42 AM
  #2028
raideron
raideron's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
JPal101, When I was going with the stock mount and the slimline, I think I
needed about 1/4" more clearence on the bottom of the firewall.. Which using
the hyde mount *should* give you, then you just have to redo the cowl mounts..
It'll make for a smoother ride :-)
raideron is offline
Old 03-14-2007, 09:58 PM
  #2029
Eric.Henderson
Eric.Henderson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I flew my first Showtime yesterday. I had put it together with an OS 1.08. The Rudder servo was in the back and the battery was at the rear of the top deck opening.
The first flight was a bit uncertain as far as tracking was concerend. I landed and moved the battery forward to the wing tube position and the result was immediate. This is a great plane to fly. I put her through the pattern paces that it clearly wanted to do. There is no doubt that this plane was already a capable 3-D plane. I did remove almost all of the expo from the rudder to get a tighter response.
All in all a great experience. The OS 1.08 was perfect in both handling and vertical performance. I had to give mine (the Showtime) to its rightful owner once I had finished testing it. You could say that I ran out of reasons/excuses to keep it in my transmitter :-)
The new owner was deligted with how well it flew. I can see him rapidly advancing his skills with this airplane.
Regards,
Eric.
ID:	642381   Click image for larger version
ID:	642382   Click image for larger version
ID:	642383   Click image for larger version
ID:	642384   Click image for larger version
ID:	642385   Click image for larger version
ID:	642386   Click image for larger version
ID:	642387   Click image for larger version
Eric.Henderson is offline
Old 03-24-2007, 09:36 PM
  #2030
JPal101
My Feedback: (32)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just got finished assembling my ST. YS 110 for power. Strange thing though, when I tried to balance it right side up it was very nose heavy, turn it upside down and it was perfect this does seem strange to me. I usually balance all my planes upside down but I thought I would see if there is a difference. Anyone have any thoughts. I am using the Great plains balancer/
JPal101 is offline
Old 03-25-2007, 10:24 AM
  #2031
isaacslaw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
JPAL:
I also attempted to use the GP CG machine with the showtime, but it was pretty difficult for me to get an accurate reading because the CG is at the very end of the range with the rulers. I had a much better time taking the rulers off of the machine and using them to measure to the recommended point -- then just using my fingers. It pays to spend some time with this plane getting the cg right -- if you go too far in either direction the showtime does not fly as well.
isaacslaw is offline
Old 03-25-2007, 06:31 PM
  #2032
raideron
raideron's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
JPal101.... I used the GP balancer with the plane inverted @ the recommended
and all placement was as stated above.... Never checked with the GP upright..
But [8D]... Before borrowing the balancer, I did mark the CG at the fuse/wing
and lined it out and used the "fingers/ply" at the wing tips on my pre first flight
setup, upright... Hence me putting my 6v battery just in Frt. of the tail servos....
Yep... very tail heavy.... Not sure if it was because of the"Fingers" at the wing tips
or the upright plane..... But I'm sticking to my story
Good job Eric
raideron is offline
Old 03-25-2007, 09:24 PM
  #2033
JPal101
My Feedback: (32)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys, I have always balanced my planes upside down. I think I will stick with that, this is no time for experimentation.
JPal101 is offline
Old 03-26-2007, 06:26 PM
  #2034
paul64
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm having a problem keeping the rear stab. up tight to the fuselage. Had them tight to the fuselage when i drilled and tapped the holes in the tube, but after a couple of flights i get a little bit of back and forth play in them. I'm concerned that after an extended period of back and forth play, the holes in the fuselage will start to elongate. Anyone got any tips as to how to get the stabs tight and keep them tight??
paul64 is offline
Old 03-26-2007, 07:13 PM
  #2035
Ron Kinsey
Ron Kinsey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
EPOXY!!!
Ron Kinsey is offline
Old 03-26-2007, 07:33 PM
  #2036
paul64
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for the suggestion...but epoxy is deff something i didn't want to do. If the stabs ever got damaged and needed to be replaced, i don't want to have them epoxied to the fuselage.
paul64 is offline
Old 03-27-2007, 07:26 PM
  #2037
blk96gt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My stab has a decent amount of play, but I have just kept flying it. Hasn't caused me any problems for 50+ flights.
blk96gt is offline
Old 03-27-2007, 08:13 PM
  #2038
go vertical
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I glued mine on . If I have a crash I garinte just replaceing a stab will be the least of my damage
go vertical is offline
Old 03-27-2007, 08:45 PM
  #2039
Ron Kinsey
Ron Kinsey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree. The stab is usually the only thing left untouched on my wreaks. That's why I glued mine...
Old 03-27-2007, 09:18 PM
  #2040
Iflyglow
My Feedback: (79)
Iflyglow's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does the show time have a carbon wing tube, and if so what size is it. I am looking for a 22 mm wing tube.
Iflyglow is offline
Old 03-28-2007, 01:03 AM
  #2041
Patto
Patto's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Showtime has an aluminum wing tube, not sure of the measurements...
Patto is offline
Old 03-29-2007, 07:32 PM
  #2042
paul64
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the tips guys. Maybe i'll just leave it be for now.
paul64 is offline
Old 04-09-2007, 06:17 AM
  #2043
BAS
My Feedback: (28)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok guys i need some advice. I am getting ready to balance the showtime, running a Ys 110 with a 2100 metal 5 cell receiver pack. I just need to know after reading some previous posts most of you folks are checking balance with the plane inverted . Need to know what is the best cg for general flying . Going to do mostly pattern type flying. Thanks
BAS is offline
Old 04-09-2007, 07:18 AM
  #2044
isaacslaw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My batteries went on tied to the wingtube. I have noticed a big difference in the way the showtime flies with cg adjustments. I have a regulator and 2-cell lithium. With a forward cg, the showtime lands much easier (for me). It will not flat spin very well like that, though, and 3-d type maneuvers (hovering) are much more challenging. With a rearward CG, the 3-d stuff is much easier, but landing becomes a bit tricky (for me). On approach you have to keep airspeed up or the tail wants to drop -- I usually come in with about 3 clicks of throttle and give a slight touch of down elevator.
Old 04-23-2007, 09:54 AM
  #2045
Gutaaaooo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A while back I saw a link for a f3a setup showtime around here, but now I´m looking everywhere, and can~t find it. Can anyone please help me out??? Tks!
Gutaaaooo is offline
Old 04-23-2007, 12:49 PM
  #2046
isaacslaw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try this thread -- pretty good [link=http://www.rcuniverse.com/forum/m_3329224/mpage_1/key_showtime/tm.htm]Showtime Pattern Thread[/link]
Old 04-23-2007, 02:45 PM
  #2047
nsoward
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just finished my Showtime 90. Installed OS 120 AX in it. On the third flight the left wing ripped off. Looks like the fuselage failed at the wing bolt. I was flying at about half thottle straight and level. The engine was running rich as I was still breaking it in. Damn expensive 3 flights.
Gave Horizon a call their comment was: engine is to big sorry
[sm=cry_smile.gif]
Nathan
nsoward is offline
Old 04-23-2007, 05:40 PM
  #2048
Gutaaaooo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tks isaacslaw, that was the one.
sorry to hear about you loss nsoward, i just set mine up with a 120ax too, hope it dosen't hapen to me. I used the futaba 3050 on elevators and ailerons for $ reasons, but now find that they have a pretty significant play... can anyone coment on that??? I'm pretty new to the hobby, other then my trainer only have a venus 40 and a sig wonder with a .25 engine that really fly's FAST. Anyway, I'm a bit woryed about the play... in the ruder I have a s9155. Tks!
Old 04-23-2007, 09:18 PM
  #2049
HoverLoW
HoverLoW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nsoward, sorry for your lost. This is a bad bad luck.
I have a Showtime with an O.S 160 FX flying hard for a year now. It's a great combo. It's the better plane I had in my life.
Your engine is not too big. Your plane came with factory problems and Horizon needs to give you another one.
I love the planes of Hangar 9, but I have a complain to do. They take much serious the relation of the manufactures to sell your products. I mean, Hangar 9 + Saito/Evo + JR. They don't give us options to choice our combination.
I purchased a Funtana X 100 now and this plane have the same problem of Showtime and the others plane of H9. The engine mount is not ajustable and the firewall is pre-drilled. You only can fit a Saito 100 or an Evo 100 in this planes.
BUT EVERYONE KNOWS WHAT A SAITO 100 OR AN EVO 100 IS NOT ENOUGH ENGINE TO PUT THIS PLANE IN YOURS HOMES: THE 3D FLY.
So, if you buy this planes to do what they are designed for, you have do modify hard the firewall (risking to ruin your plane), put a bigger engine and lost the warrant.
I think this is a disrespect with the costumers. This is a expensive hobby and I don't have money to and patience to ruin my planes (a 3d plane without a good engine is losted like a plane with the firewall ruined).
I know they want to sell your products, but they can't to compel us to buy a Saito 100 to put in a Showtime or Funtana.
Great Planes works with O.S. engines. Everybody knows they are the biggers manufactures in this hobby (Great Planes, O.S., Futaba and Tower Hobbies). They mention each other your manuals, but Great Planes, for exemple, provide your planes with ajustable mounts.
You can install a Saito 82 or 91 in an U-CAN-DO 40.
Well, this is my complain. I hope you all can understand me. I am brazilian and my english is a problem..
HoverLoW is offline
Old 04-23-2007, 09:24 PM
  #2050
Gutaaaooo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: HoverLoW
Hey man! It seams that there are many of us around here!!! Bons vôos!
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
