Great planes ultimate 160
Reply
Old 10-01-2012, 11:23 AM
  #6851
iflywhenican
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Great planes ultimate 160
Very nice job Gordon. I know that you will enjoy this plane.
iflywhenican is offline
Old 10-01-2012, 11:36 AM
  #6852
69 roadrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have one with a 50cc on it flys great I havent flown it in about two years been fling 100cc extra 300 but seeing your plane i think its time to break out and fly again the plane just flys so great its a shame to just let it sit Steve
69 roadrunner is offline
Old 11-12-2012, 04:06 PM
  #6853
Fl_Matt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am putting a new DLE 55RA on this plane and wanting to use a Vess Prop. Question is what Size and pitch should I go with? Any input would be appreciated.
Fl_Matt is offline
Old 11-12-2012, 04:24 PM
  #6854
mstcitabria73
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Break in prop Vess 22/8-10, Vess 23/10 after break in.
mstcitabria73 is offline
Old 11-12-2012, 06:08 PM
  #6855
Fl_Matt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Sir
Fl_Matt is offline
Old 11-26-2012, 04:28 PM
  #6856
Fl_Matt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So Far I am setting up my Ultimate with
2) 3200mah life batteries
Wike R/c IBEC w/ optical kill for ignition
Spectrum 9ch Powersafe reciever and failsafe switch
Savox servos 0251 on Ailerons and Elevators, 0254 on throttle and 1256tg on rudder
DLE 55 RA engine
Vess 22A prop
Carbon Fiber Spinner
Dubro Flat pinned hinges all surfaces
Carbon fiber rod over 4-40 for all contol rods with ball links
Hangar 9 rubber tires
Fl_Matt is offline
Old 11-26-2012, 04:41 PM
  #6857
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the DLE 55 in mine with a 23-8 prop.  And in has unlimited vertical.
acerc is offline
Old 11-26-2012, 05:53 PM
  #6858
tiger650
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: acerc
Same with me, dle55 and Xoar 23x8 prop. Awesome plane. I never tire of flying it!
tiger650 is offline
Old 11-26-2012, 05:56 PM
  #6859
PropsnWings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a DA 50r for mine... But I do have a new DLE 55 sitting too.  Maybe I should make a change in my plans before I get to my project for this winter?
PropsnWings is offline
Old 12-09-2012, 04:33 PM
  #6860
Fl_Matt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Almost ready, just need to set the throws and give it a good once over.
ID:	1828323   Click image for larger version
ID:	1828324   Click image for larger version
ID:	1828325   Click image for larger version
ID:	1828326   Click image for larger version
Fl_Matt is offline
Old 12-09-2012, 04:48 PM
  #6861
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok Matt! You gotta get rid of that baby and put in a doll. LOL
You like flyin on the edge of your seat? You will love this plane.
acerc is offline
Old 12-09-2012, 05:23 PM
  #6862
mstcitabria73
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: acerc
I have the DLE 55 in mine with a 23-8 prop.And in has unlimited vertical.
DLE 55 is very strong, pulls mine vertical out of sightat about the same speed as flying level wide open, good combination motor/planefor sure....
Old 12-14-2012, 07:05 PM
  #6863
Fl_Matt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All finished. Throws set to the book, batteries charged. If all goes well I will run the engine and get her tuned tomorrow. If that goes well I may put her up in the air.
ID:	1830064   Click image for larger version
Fl_Matt is offline
Old 12-15-2012, 02:03 PM
  #6864
Fl_Matt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I must say that is the best running engine I have ever had to set up. 1/16 turn richer on low and 1/8 turn richer on high and it transitioned perfectly spun the 22A at 7550 (peak was 7650 richened it till it went down 100 RPM) no burble at all.
I started on low rates thank God, plane was a little tail heavy. I originally checked the balance at 1" in front of rear cabane hole (wings off) but after a real squirrly flight I did the wings on check and at 6 3/8 (book ideal point) it was extremely tail heavy. All I can think of is the servos I used on the ailerons may be heavier than normal (Savox 0251 220 oz of torque). For now Iam going to add 8oz on top of the engine posts. I checked the batteries and after over an hour of on time with ignition and a 10 minute flight it only used 302mah and I have 2 X 3200 life packs. I think I will order 2 X 2500 life packs which should lower my tail weight and allow me to remove the 8 oz on top of the engine stands. The plane AUW before the 8 oz came in at 14lbs 15 oz and now weighs 15 lbs 7 oz which is still not bad I guess.
Fl_Matt is offline
Old 12-15-2012, 02:42 PM
  #6865
PropsnWings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What engine are you using again?
Old 12-15-2012, 04:08 PM
  #6866
Fl_Matt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The new DLE 55RA .
Fl_Matt is offline
Old 12-22-2012, 05:56 PM
  #6867
Fl_Matt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got a new digital scale that is supposed to be very accurate and re weighed my plane. It is 16lb 3oz so I am definately going to get a couple smaller packs and then lose the 8 oz on the nose. Should come in around 15lb 8 oz after the changes.
Fl_Matt is offline
Old 01-27-2013, 01:55 AM
  #6868
agbjarn
agbjarn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My kit which I bought last September is still waiting in the box in my garage. I have to finish my H9 Ultra Stick 60 + DLE20 before I start building the Ultimate, probably with a DLE55.
Thanks for this great thread.
Agust
agbjarn is offline
Old 01-27-2013, 10:19 AM
  #6869
Uncas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Fl_Matt
I started on low rates thank God, plane was a little tail heavy. I originally checked the balance at 1'' in front of rear cabane hole (wings off) but after a real squirrly flight I did the wings on check and at 6 3/8 (book ideal point) it was extremely tail heavy. All I can think of is the servos I used on the ailerons may be heavier than normal (Savox 0251 220 oz of torque). For now I am going to add 8oz on top of the engine posts. I checked the batteries and after over an hour of on time with ignition and a 10 minute flight it only used 302mah and I have 2 X 3200 life packs. I think I will order 2 X 2500 life packs which should lower my tail weight and allow me to remove the 8 oz on top of the engine stands. The plane AUW before the 8 oz came in at 14lbs 15 oz and now weighs 15 lbs 7 oz which is still not bad I guess.
That is a lot of servo torque for your ailerons! The airlerons are actually smaller than what is on a UCD 46. But your servo weight is about 2 oz so I do not think that is the problem. Mine weigh about the same.
I suspect your squirrly flight is not because it is tail heavy, especially since you have 8 oz in the nose and large batteries. I actually put my 5 cell NiMH (1700maH) pack in the fuse behind the wing to get it more tail heavy for 3D flying, plus I even added weight in the tail. I am running a DA-50r. I would check my trim, even have someone trim it up during flight. Also make sure your wings are tight and properly bolted. Double check this. I have my rates set very high - I even re-hinged my ailerons for more throw to limit the Torque roll during hover. I used all stock hardware. I presume you used the tail support wires and they are tight. Another thing, this plane can fly pretty slow without stalling, no need to race it around, though it can do that too.
This is one of the best flying planes I have ever owned.
Good Luck!
Uncas is offline
Old 01-30-2013, 03:52 PM
  #6870
Fl_Matt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The squirrly flight was before the 8 oz on the front . The next thing was it balanced perfect with the wings off method but after the touchy flight I checked it with the wings on method (per manual) and the tail would drop like a stone. I trimed it out on the touchy flight, if you trimmed it for level flight at half throttle then rolled inverted it would climb at a good clip.
Quote:
ORIGINAL: Uncas
Quote:
ORIGINAL: Fl_Matt
I started on low rates thank God, plane was a little tail heavy. I originally checked the balance at 1'' in front of rear cabane hole (wings off) but after a real squirrly flight I did the wings on check and at 6 3/8 (book ideal point) it was extremely tail heavy. All I can think of is the servos I used on the ailerons may be heavier than normal (Savox 0251 220 oz of torque). For now Iam going to add 8oz on top of the engine posts. I checked the batteries and after over an hour of on time with ignition and a 10 minute flight it only used 302mah and I have 2 X 3200 life packs. I think I will order 2 X 2500 life packs which should lower my tail weight and allow me to remove the 8 oz on top of the engine stands. The plane AUW before the 8 oz came in at 14lbs 15 oz and now weighs 15 lbs 7 oz which is still not bad I guess.
Good Luck!
Fl_Matt is offline
Old 02-04-2013, 03:52 PM
  #6871
Fl_Matt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I had the Ultimate set up and flying like a dream and then an .46 size Escapade flew through my left wing panels sending the Ulti to her death. I will say the gorilla glue held great for the hinges and wing joiner and will use it again with no reservations. 5 flights was not enough with this great plane.
ID:	1848103   Click image for larger version
ID:	1848104   Click image for larger version
Fl_Matt is offline
Old 02-04-2013, 04:22 PM
  #6872
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I feel your pain. I lost my first one due to a faulty servo cutting everything on and off. But liked the few flights so well I got one 3 days later via UPS. A real sweet plane.
   Sorry for your loss!
acerc is offline
Old 02-04-2013, 04:26 PM
  #6873
mstcitabria73
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sorry to hear that about your Ulti FI_Matt, hope your gear and motor came thru unscathed! Your next Ulti will go together quickly after already doing the the first build, good luck................Mike
Old 02-04-2013, 04:39 PM
  #6874
Fl_Matt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am missing 1 servo and 1 servo the wires are shredded, carbon fiber spinner done, the IBEC is done, the ignition and muffler are garbage but the engine itself looks perfect. I will need to check the crank for runout to know for sure. All the other servos and recievers are perfect as well as the batteries. There was about a 8" section of both top and bottom wing that were turned to toothpics and just happened to be where the aileron servos were.
Fl_Matt is offline
Old 02-04-2013, 04:57 PM
  #6875
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you need to get your, Ultimate, fix while your waiting, come over to my club. I'll let ya fly mine.
acerc is offline
Reply
Display Modes
