Mini Funtana Goes GLOW!!!!
QC, CANADA
RE: Mini Funtana Goes GLOW!!!!
Nice lol !
Already saw the mini funtana with a glow engine...dont know wich one cause it was under the cowl..Didn't saw it fly cause it was over 25 m/h of wind lol
Julien let us know how it flies !!
My Feedback: (17)
Damn ya beat me to it, i litterly just started working on mine some tonight, but i gotta alot of repair work to do, plus im totaly recovering it. i think im gonna go with an OS LA 15
Hi Guys,
What modifications did u do to change this to glow ?, plus was it hard to do ?
Im very interested in getting one soo plz try to keep us posted
Thx
Thx
My Feedback: (17)
ORIGINAL: DragonHeart
Hi Guys,
Thx
Hi Guys,
Thx
Other then that the rest is simple, get a .15 size motor mount, drill the firewall and install blind nuts for the motor mount, put your fuel tank where the batterie normally goes witch is right behind the firewall.
Thats about it GL [8D]
My Feedback: (15)
FL
I can't wait to try it. If the 10 motor isnt enough we are going to put a os15 on there but it should be enough I hope. We didnt add and extra ply to the front. We think it is strong enough for this motor. The stick that goes through to hold the electric motor seems like it supported the front really good after we cut it off.
MA
I finished mine about 2 months ago. It has about 25 flights on it now and it goes to the field almost all the time to fly. I put another firewall right over the one that is on the plane and epoxied it real good. I had to replace the landing gear with a stronger one and support the bottom better for it. Just had to epoxy everything real good and it has been holding up great. I put an OS .15 LA in the one I use and it flies fast enough with enough power. The landing & take offs are a breeze with it.
MA
I am using a Futaba FPR 127DF & JR NES 241's. I had 3 flights on it yesterday and 3 the day before. Please note that I had trouble with the OS .15 LA. I finally had to take off the backplate and make a gasket with High-Temp RTV silicone (RED) and lock thight the screws in. That stopped the air leaks and it runs great now. I did the same to by OS .46 LA having the same problem with air leaks.
My Feedback: (15)
FL
Today I tried it and the motor is new so we had to run it some today but cant seem to get it right. It is getting Way too hot. So we couldnt fly it today. The servos im using are micro jr digital servos.
awesome forum guys, i have been kickig this idea around since the first time i saw mini funtana, but.....i am all 3-d and need to have a engine up front to match, any suggestions would be great, also, on a plane with engine this small is it possible, or safe, to use an electric prop for better thrust? have NO experience with stuff this small ( my planes: funtana 40, twist, laser 3-d, expo 3-d, 25 percent gas katana, and a homemade 60 size foamie that can teach anyone to fly 3-d)
My Feedback: (17)
The mini wont be much for 3D with a glow motor on her, not only is she gaining some what, but your also going from a 12 inch prop to a 8-9 inch prop at the most, the electric version will 3D much better.
NB, CANADA
hey im thinking of putting an os fs series 20 in a mini funtana has anyone tried this and is it a good idea i also have a 2 stroke 10 if thats way better
PE, CANADA
hey i actually posted that thibg under servo 7 it was already logged in at my job when i was on my lunch break and i used it by acciedent but i really need to know if its a good idea to put a os fs series 20 ( four-stroke ) in a mini funtana.
My Feedback: (17)
I was thinking about doing an LA25 i mounted it just for fun to see how heavy it was and really it wasnt bad at all, i didnt actully wiegh it but my guess would be about 27oz
PE, CANADA
Thanks guys i think i will try it and tell ya how it works it should be awesome and hover at like quartre throtle or most half so i guess i will probably try it thanks. cuz if the 20doesnt work i have a 10 15 20 36 to 47s etc 2-stroke so one of em should work
