DP Extra 330 and YS 140DZ
BC, CANADA
Has anyone flown a Dave Patrick Extra 330 with a YS 140DZ? Any comments as to the combo would be appreciated. I'm looking for 3-D performance.
Thanks!
Thanks!
I think that the YS 140 will not be enough. A Moki 180 is recomended.
Here is video of mine. www.3dbatix.com
look under videos
look under videos
Great Flying!
Great 3d flying....How much does your DP 330 weigh with the 2.10...Have you seen one fly with a gasser? Are you using a gyro at all? Seems really stable in harrier and hover....Iv'e never seen anybody do left harrier rolling circle with right rolls except Higuchi.....Lookin' forward to more videos.
My Feedback: (38)
Jasah
I tried a 140L as it was the "recommended" engine of choice when the plane first came out. I was sorely disappointed and unless the DZ has twice the power, which I doubt, you will be diappointed also. 50CC or large Moki is the way to go. Just my 2C worth
Paul
Paul
I'm doing some awesome stuff with mine, quite a bit higher though . Gyros aren't necessary to fly this plane 3D, but something with some good power like a large Moki is.
No need for a Gyro in any fixed wing model.. it only teaches you to be lazy... if you cant 3D without a gyro... practise or give up... practise is usually the best thing.... I would appreciate a gyro during inverted harriers looking at the top side.. i keep using the theory that's used when flying the model towards oneself, thus making it go wrong.. nearly got it perfected to a point that i'll bring it really low now.
I agree with Chris540 and Welsh3D, gyros are for those noisy inverted lawn mowers only . No gyros on the planes, its cheating.
Gbond, the plane is about 15 lbs, and I have not flown one with a gas. I am going to get a new Dave Patrick Edge 540T, and it will have one of the new ZDZ 50's on it. Im sure it will be plenty of power, and the weight is about 5 oz more than the moki. This is ok though because the new DP kits are lighter in weight. I probably wont have the components until around January, but I'll keep ya posted.
...now i'm even more impressed!...knowing that you weren't using a gyro - cool stuff!...
...i'll show my ignorance here, but...to do the left harrier rolling circle w/continuous right rolls - to do it rock solid like in the video - i assume you've got to be making some pitch corrections with the elevator while doing the rolls - you can't just hold ailerons to the right...correct?...
Thats how I like to do my harrier rolls....and I can tell you it takes WAY more than just aileron!
rudder...elevator...aileron...throttle are all used to do it right.
My Feedback: (54)
PA
I have the DP 330 thatI didn't fly it yet. It has a YS140. So this motor won't make it fly 3D or have unlimited vertical, hover or torq roll? It has a 16x8 APC prop and going to be using 25% nitro fuel
Which YS 140 is it? The FZ or the L or the DZ?
If it is the L or the DZ, I think that you would need to increase the prop size a bit. I have a 16x11 on my 140L, and I think that it is running too fast.
What type of engine does it say it is on the box? I'd say the FZ won't do well, thw L would be lively, but not exellent, and the DZ would be the best of the YS's.
...interesting comments guys - but one thing i don't understand - i thought i'd read where most of the TOC competitors use gyros - am i wrong on that?...
My Feedback: (10)
TX
TX
QC, CANADA
RE: DP Extra 330 and YS 140DZ
I have a 140 DZ and it turns an APC 18x8W at 8400 RPMs on 30% nitro. It pulls my 11 lbs smaller-than-DP-Extra airplane with authority but not that much power to spare. I would think the newer 160DZ would not even be enough for the DP Extra.
GYROS are used by some of the DEMO pilots, but are illigal in any competition. Start with a good plane, set it up correctly, and pratice is the best gyro.
I only really learned to torque-roll with my Funtana 40. From there, the larger planes are easier.
Rolling circles and loops and harrier rolls/rolling-circles are done with constant roll rate; the roll, or loop or straight harrier part is done with the correct amount and timing of the elevator and rudder inputs.
Do a search on Mark Leseberg, and you will find interviews and videos on his rolling circle harrier (one is on RCU team, the other is on Scale Aerobatics.com) . He may currently be the best at this, and he recommends 5 hours a day on the simulator to master this. Unfortunately, I don't have the time nor the simulator. But I do fly my planes (check out my gallery below) intensely on week-ends.
Practice hard.....Maybe,.... but above all, ENJOY THE FLYING !!!
I had a DP EXtra with a YS 140DZ on it and it was a wonderful combination. No trouble pulling out of a hover. I was using a APC 18x6W and getting 9800 rpm's peak. I flew at 9600 rpm's and it was a blast. Some of the advantages were the light wing loading and great throttle response. Right now the 140DZ is on a Kankge CAP @ 13.5 lbs. It will do anything I am able do. I had a OS 160FX on the DP Extra and it did not make the grade. I would skip the Moki 1.8. If I went to a Moki it would be the 2.1 as there is very little difference in weight so you might as well get the extra power. BTW if you go to a Moki give it a great deal of break in after that it will be a very good engine.
